Headlamp lens removal
Old Aug 4, 2019 | 02:36 PM
mrdavis's Avatar
Folks, hello. My son decided he wanted to remove the lenses on the '08 Fit to give the interior light a good cleaning. OK, I said. We started prowling about the lenses and I decided a trip to YouTube was in order. But I didn't find anything specific to removing just a lens; the videos all detailed how to remove the headlight assembly.
Can anyone provide some insight into this before I break a big piece of plexiglass? Thanks.
Old Aug 4, 2019 | 04:49 PM
doctor J's Avatar
The entire headlight is fused together on the factory.
Old Aug 6, 2019 | 08:47 PM
domoMKIV's Avatar
You can put them in the oven or use a heat gun. Either way you have to be careful.
I have used the oven method far more than the heat gun but success with both. Are you sure you need to take them apart to clean them? If they are hazy or yellow its probably just on the outside.
Old Aug 7, 2019 | 07:19 AM
mrdavis's Avatar
This is good advice, and thank you both. No, I am not sure I need to remove the lens -- and have decided not to do it. It ain't broke, or not broke enough, to attempt this. I will urge my son to find something else to fix. Thanks.
Old Aug 7, 2019 | 08:31 AM
NEGD3's Avatar
Yea, If the lenses are yellowed or foggy, the outside of the lens can be cleaned, wet-sanded and polished to restore them. I just did mine the other day, they look brand new now.
Zero2Hero
May 28, 2018 04:55 PM
NightScreams
Jul 26, 2015 04:21 PM
ScaryDolphin
Feb 21, 2015 05:17 PM
madhartigan
Dec 19, 2008 03:18 PM
99CivicCX
Jun 3, 2005 01:06 AM
