Weird problem; stuttering intermittently, not a misfire (but feels like it)
Hi there, I just changed my battery to a... can't remember, but a larger battery that fits without rubbing up against anything.
Since then, I've noticed what I thought was an occasional misfire. I bought a scanner and it said that all cylnders are firing as "passable."
One thing I noticed is that if I have the AC on, it seems a little more likely to happen. Also, in stress testing it, the headlights don't dim, but the interior light definitely flickers.
My partner thinks it occurs often when braking, which I didn't notice until yesterday when it was driving perfectly around town until I braked, and it really started shaking. Weird.
Could this be a battery thing? I've had the coil packs changed about 100,000km ago. Didn't ever change the plugs.
Has this happened to anyone before?
TIA!
TIA!
The battery itself should not be the cause of this. However, when you replace the battery it is sometimes necessary to run the idle relearn procedure (though I didn't have to run it after disconnecting my battery):
ECM/PCM Idle Learn Procedure (5MT)
Make sure the battery terminal clamps are tight and clean. You shouldn't be able to move them with your hands. Otherwise, this issue is entirely unrelated to the new battery!
Thanks! Yeah I'll ask a mechanic or three how much they think it will cost. Looks kind of fun to DIY as well, but I'm always afraid of screwing it up.
Yup, first thought it was a misfire due to bad coil packs. The original coil packs were swapped out 100k ago. Car runs a lot smoother now, so long as I don't crank the heat. I'll do valve adjustment soon...
Yep your due for a "full" tuneup,
The GD NEEDS the valves adjusted every 60 to 80 K Miles. Its a solid valve train engine..
The plugs should be changed about the same
Coil Packs too buy Hitachi from Rock auto they are fine.
The exhaust ports are right next to the hole the plugs go in the hot exhaust
bakes the bottoms of the coil packs. I had the head off mine once you see that way,,
it makes sense..
Make sure all the ground cables are in good shape, the power the AC clutch and
radiator fans draw will cause odd things to happen.
it makes sense..
It is from the great honda coil packs. Actually it is noting wrong with the packs. You need to clean them and add some dielectric grease. It will take about 2 hours labor and $10 for grease. Search in the forum there is very good thread I read 5 years ago and no issue after it.
ikutoisahobo
Oct 2, 2019 01:58 PM
ALLDAYKK
Feb 13, 2015 03:02 AM
Mini_Odyssey
Apr 21, 2013 07:37 PM
