It may not even be from your car. It may have lodged into the chassis from driving over it. Or you just ran over it. It looks a tad big to be a Fit part.
Thank all. I had a look under the back and the springs look fine there. Sorry for the stupid question but are there coil springs in the front and if so, how do I see them? Can't see by looking under car. Does it need to go on a lift?
Thanks all. Just to update, it was the front coil spring. Mechanic has been waiting on the part for nearly a week now (apparently it's hard to find) but should be fixed this week.
Funny, I found the exact same piece of the coil on my driveway this week. Sure enough front driver side is broken. Seems like it is hard to find OEM springs, going to get H&R all around.
No, I'm not taking it to the track.. The kit was described as aggressive street driving or novice track. I just wanted a tighter suspension all around. To be honest, I drive around this round-about and I just hated the lean/sway the car would have going around it - at normal speeds! Good reason to upgrade :-).
