Starter noise after cold start revisiting
Old Nov 3, 2022 | 09:36 AM
doctor J's Avatar
Talking Starter noise after cold start revisiting
For those who are still intersected in finding a root cause of this issue instead of ignoring it or installing painted POS with "lifetime [trouble] warranty"
Today the temps were in low 40s and I think i heard a brief screech after engine started, meaning the issue is coming back (had no noise for 3 years)
I used high mileage starter with aftermarket solenoid (That uses dry plastic sleeve around plunger)
However during installation I placed black rubber plunger end cover which is getting hard and stiff during the cold weather and may cause delay in plunger return
If issue persists I will take it out and see if it makes a difference (1 hour fun with starter R and R, but I like to work on car, you know!)
I will also test the overrunning clutch by holding key in for 2 seconds after engine starts; defective clutch will make a hell of noise)
Other possibility is dirt or or step wear on the starter pinion shaft
Old Nov 5, 2022 | 02:49 PM
Breezer's Avatar
Thanks.
Looking forward to updates.
Old Nov 6, 2022 | 09:52 AM
Mister Coffee's Avatar
I'm following this thread . . . but it's like a scary movie. I'm afraid, very afraid.
Old Nov 6, 2022 | 06:05 PM
doctor J's Avatar
The coming week will be at low 40es, so will see!
Old Nov 15, 2022 | 07:16 PM
PattyWax's Avatar
following this, got the same prob
Old Nov 27, 2022 | 08:27 PM
doctor J's Avatar
I went ahead, took my starter out and installed the starter drive from newly re-furbished Denso reman. for Honda starter from the Junk yard Let's see if this will support my newest theory!
jond63
May 10, 2024 10:45 PM
doctor J
Nov 11, 2023 11:38 PM
temoc
Nov 6, 2022 06:18 PM
doctor J
Feb 20, 2019 05:55 PM
Santiad
Dec 28, 2013 01:03 AM
