Blanking EGR valve
Old Feb 8, 2023 | 06:04 PM
dbcl's Avatar
Blanking EGR valve
2007 GD1: 1.3 L L13A i-DSI
I have blanked it and now, predictably I suppose, the valve is throwing OBD2 codes and putting the EML on.
Can I stop that happening, maybe by fitting a thick gasket between the valve and the blanking plate so the valve doesn't touch the plate on opening? Or drilling the plate (when removed of course) with a small hole to allow some pressure relief to the valve?
Old Feb 15, 2023 | 03:17 PM
elkaku's Avatar
The problem persé is that the sensor won't detect the correct flow of gasses on the system.... The only way to make the code not light up is by using either a KTuner or a Hondata to disable it....
mowfixer
Apr 30, 2022 05:14 PM
amberd03
Aug 20, 2017 11:57 AM
sunnyday
May 27, 2017 09:18 AM
icedmocha
Feb 9, 2015 05:58 PM
