07 Fit Sport rough idle, codes P0499, P2649, P300,P0301,P0303,P0141
Old Nov 14, 2024 | 12:53 AM
Fit2000's Avatar
Question 07 Fit Sport rough idle, codes P0499, P2649, P300,P0301,P0303,P0141
So today I hadn't started the Fit for 2 weeks. Initially it didn't start but it did on the 3rd crank. It idles rough as if misfires are occurring.
Scantool shows the following codes:
  • P0499 $18DAF110 - Evaporative emission system vent valve control circuit high
  • P2649 $18DAF110 - A rocker arm actuator control circuit high bank 1
  • P0300$18DAF110 - random/multiple cylinder misfire detected
  • P0301 $18DAF110 - Cylinder 1 misfire detected
  • P0303 $18DAF110 - Cylinder 3 misfire detected
  • P0141 $18DAF110 - O2 sensor heater circuit bank 1 sensor 2
It seems to have slightly improved after idling for 10 mins.
But here's the real interesting part... if I have something plugged into the OBDII port, I hear constant clicking maybe twice per second, so very fast, on the relay panel under the steering wheel. Also, I seem to get shocks occasionally when touching the body of the car. In the past, the speedometer had been jumping so I plugged in an OBDII HUD which made the speedometer work okay and gave me a HUD speedometer. Is there a chance this could all be a dying relay?
Before I go throwing parts at it (e.g. new rocker arm oil control valve), do you think it could be a relay?
The Fit has been running fine for some time and it seems all the misfires and some other codes could just be related to a single minor cause.
Any ideas would be greatly appreciated.
angus.mundy
Dec 15, 2024 12:16 AM
DirtyHammmer
Jun 17, 2024 01:46 PM
Alex Smith
18
May 21, 2024 09:56 PM
Nydhog
Dec 17, 2018 12:13 PM
nielmot
Mar 2, 2017 07:54 PM
