Intermittent ignition issue
Old Dec 2, 2024 | 09:20 PM
Fitas's Avatar
I have 2005 Honda Fit
earlier in the the year I started to get intermittant issue with car ingnition not working proprly . Key goes in fine , then there are two "clicks" when you turn the key. Both work fine and all the correct lights come on after the second click. Then when you contiuue to turn key there is no starting of the car. Sometime a wee wiggle makes the car start. I have the ignition switch replaced and the issue went away for about six months.
it's started to happen again. So curiuos to know if this is a common problem .
Zardiw
May 28, 2022 11:16 PM
JonStewartMill
May 12, 2022 05:20 PM
Bluecrayon
Apr 6, 2021 01:14 AM
pablolo
Dec 8, 2020 11:03 PM
HighMileage07
Jul 20, 2020 10:16 PM
