Defrost & A/C lamps quirky
Old Mar 28, 2009 | 12:48 PM
FrogDaddy's Avatar
Not sure what to search for so I'll post. I've noticed when my lights are on my A/C lamp is out and my Defrost lamp is loose or something. If I tap the defrost switch the lamp blinks. I'm talking about the night alumination not the on/off lamp itself. I want to take it apart to see if bulb or switches are loose behind but I can't seem to find manual or docs on forum. I'm aware of a winrar file for the jazz online but nothing here on the forum that shows how to swap stereo or other such disassembly for this area of the vehicle. Any pics and or help would be great. In meantime I'll keep searching and hopefully won't break plastic .
Thanks in advance.
Old Mar 28, 2009 | 03:03 PM
HONDAMATIC's Avatar
if you got warranty bring it in.. i think the audio section tells you how to remove the radio, which contains the climate control
Old Mar 28, 2009 | 03:05 PM
FrogDaddy's Avatar
found the ipod music link pdf. that's what I was looking for.
thanks.
Old Mar 28, 2009 | 04:21 PM
Interstate526's Avatar
yeah. and it says that after you remove the two bolts it "slides" forward. This is not true. It's more of a yank, scream, cry, give up for an hour, and pull until it comes out. Once you figure it out, it's not so bad though.
i'd recommend unplugging the fan speed switch. I broke mine when i pulled my HU, and it seems like a common thing to break.
BlackFit07
Fit I.C.E.
63
Jun 24, 2011 07:43 AM
sethne
Jul 8, 2009 09:14 AM
07fitsport
Dec 30, 2007 12:28 AM
theo
May 29, 2007 08:38 PM
howardlhughes
Sep 6, 2005 11:20 AM
