Uneven brake pad wear?
Old Mar 16, 2010 | 01:06 PM
.eL's Avatar
.eL
I replaced my rotors and pads just over a year ago and recently I noticed my brakes were making a low frequency noise, almost grinding noise, when I would slow down.
I checked and my rotors have a lip around the edge like I'm digging into them. It's a bit worse on the right side of the car. I have a bit of "meat" left on the pads but they look pretty worn for only 1yr and maybe like 20k miles.
Any idea why the wear would be uneven or why I'd need to change my pads so soon? It's not aggressive braking as I'm pretty easy on my brakes and these were EBC pads and brembo blank rotors. I would assume they'd last longer than stock but that's not the case here.
Old Mar 16, 2010 | 02:21 PM
DeNNis.'s Avatar
i have the same issue, hope one of the fitfreak members can answer
Old Mar 16, 2010 | 06:37 PM
NBPturtle's Avatar
I remember reading somewhere on her awhile ago that the uneven break pad wear is a problem with the fit....I dont know at about 20k though...seems weird.
Old Mar 17, 2010 | 01:20 AM
loud_tiger's Avatar
when do you guys get new pads or rotors? i'm at 45k and haven't noticed anything wrong or worn.
Old Mar 17, 2010 | 04:12 AM
JDMGD85's Avatar
I don't like stock brake of the Fit. I'm at 30000km and they are not so ready...
Old Mar 17, 2010 | 03:32 PM
wobuffet's Avatar
i have the same problem
i heard rotors are supposed to be changed every 60 000 kms but i had to hve mine changed around 40-50 000 kms. i just passed the 80000 km mark recently
got mine changed just about a year ago and i'm having same issue again these couple days..the worst is when braking at a downhill...my legs shake like crazy from absorbing the impact from brakes to pedal to leg
Old Mar 17, 2010 | 08:01 PM
Perrenoud Fit's Avatar
Talking Where's the Pichers?
TTISWP.jpg?t=1264848022
Old Mar 17, 2010 | 08:14 PM
Thumbs up $85.00 shipped to ur door with ceramic pads!!
I put these drilled rotors on a year ago and have had really good results with them. From what I have read the holes dissapate the heat faster so they are less likely to warp. The slots on rotors from what I have also read are for keeping the pad surface from glazing but in street use the slots just remove more material off the pads.
Old Mar 20, 2010 | 07:16 PM
.eL's Avatar
.eL
At 35k mi, my rotors were warped and my brakes pulsed really bad. Something must be wrong because I'm not harsh on my brakes at all.
Old Mar 20, 2010 | 07:28 PM
im the fit's Avatar
I noticed that with my powerslot cryo rotors and hawk pads but bleeding will take care of it...PS old school pumping the brakes for bleeding wont work you'll need a bleeding gun!
Old Mar 20, 2010 | 07:33 PM
im the fit's Avatar
I didnt mean to quote I never had pulsing lol
Old Mar 20, 2010 | 11:30 PM
gimme's Avatar
Master FitFreaker
a link to where you got them would be a nice gesture
Julien Griffault
May 14, 2021 08:04 PM
phenoyz
Jun 3, 2014 11:52 PM
BDT
22
Apr 20, 2012 04:32 PM
mikejet
Sep 12, 2009 11:12 PM
goodyonsen
May 22, 2009 06:30 PM
