Non vtec Jazz/Fit CVT auto tranny problem.
Old Nov 25, 2010 | 08:43 PM
vtecdohcter's Avatar
hey all, my first post.
i know there is problem with the CVT auto tranny on the GD version. is there anyone here managed to fix it?
Old Nov 27, 2010 | 10:49 AM
may be i need to be more specific. the problem/symptoms is vibrations on initial gear then jerkings ( all thru gear change i presumed) till about 50-60km/h.
Old Dec 4, 2010 | 04:57 AM
F0NIX's Avatar
I have a Jazz GD1 with CVT, and have not had any trouble with it so far (40.000km).
I can't say I have heard any other have had problem with it either.
Just remember to use the correct oil on the tranny when changing the tranny oil.
Old Dec 4, 2010 | 07:20 AM
from your Sig it says you have the 2007 model..am i correct? i have the 2003 and have own it since 2003 for almost 8years. the symptom will appear after3-4years of driving. but then again it depends on how you drive them.From a thread i read somewhere (i forgot where) it says that we supposed to change the oil every 10-15k..not as per the manual. so if you changed them as per manual, then start doing it every 10-15k. it will happened. the early symptom is shuddering at start of moving fwd. then if you dont fix the problem, it will become obvious like shaking of the whole car then jerks as i have explained earlier in the thread. i only found out about the oil change when it was already too late. i have bought a shop manual where it has the list of symptoms which include this one. it says i need to replace the fwd clutch, start clutch and few other parts. im wondering if anyone had done it.
Old Dec 7, 2010 | 10:08 PM
Xishgee's Avatar
Hi guys i have a 2001 GD1 Jazz. now my trip is 25000km i have to change my cvt transmission oil please tell me the oil number or serial and name what kind of oil we need? I live in Mongolia
Xishgee's Avatar
Mongolian winter is too cold 35 - 40celcium
Old Dec 8, 2010 | 05:54 AM
patyong's Avatar
You guys will need this CVT transmission oil (Part number: 08269LUB001 given in the picture). Only use CVT transmission oil from Honda.
Old Dec 8, 2010 | 11:40 AM
to be exact.. Idemitsu made for honda.
Old Dec 9, 2010 | 05:51 AM
Xishgee's Avatar
Thanks a lot man do you know to the price? maybe is this very expensive
Old Dec 10, 2010 | 07:17 PM
patyong's Avatar
It's very expensive over here in Australia - AUD$100 for 4L. Singapore cost bout SGD$40 - $50 for 4L. My suggestion is to ring up your local Honda dealer to ask on the cost for 4L.
Old Dec 10, 2010 | 08:22 PM
this thread kinda going off topic...
anyway, try look up for Idemitsu CVT oil which probably be cheaper (if available) than the Honda packaging cvt as i mentioned before Idemitsu made those cvt oil for honda. honda just have it specially package under their brand and sell it at slightly higher price.
teamjm
Jan 29, 2013 10:43 PM
agcat1981
Sep 14, 2010 04:45 AM
Master_Scythe
Nov 7, 2009 07:34 AM
JazzEr
Mar 5, 2006 12:48 PM
shaolin
Oct 23, 2005 11:35 AM
