SRS Airbag Red Light
Old Jan 25, 2011 | 07:19 PM
wlfit's Avatar
Is anyone else getting an intermittent red warning light for the Airbag SRS in the gauge cluster?
I took it into the dealership and they ran a diagnosis, restarted the "computer" and it went away. Within 15 min of driving it popped back up.
I'm definitely not paying to replace the airbag... anyone else getting this? Any resolution?
Old Jan 25, 2011 | 09:41 PM
hogwylde's Avatar
That could be a "costly" mistake.
Old Jan 25, 2011 | 09:46 PM
kylerwho's Avatar
spoon fed
unplug the seat airbag clips and re plug them back in. some times they come undone because passangers can hit it with their feet.
Old Jan 26, 2011 | 09:36 AM
wlfit's Avatar
seat airbag clips
Right on. I'll give that a try. Is that connector under the seat?
The light seems to come on after the car warms up.
I had leather seats and a sunroof installed in my car... a lot of annoying issues seem to have been a side-effect of this. However it was worth it.
Old Jan 26, 2011 | 03:24 PM
kylerwho's Avatar
spoon fed
maybe the guys who installed the seats didn't connect the plugs all the way. yes they are right under the seat.
Old Jan 26, 2011 | 04:00 PM
wlfit's Avatar
The code is 32-10. Which is passenger airbag related. There is a TSB out on the civic for the same code - that resolution is a wiring issue. I think it's a wiring issue. I'm going to mess around with the SRS wiring on the passenger seat and see if it fixes it.
Old Feb 11, 2011 | 09:32 AM
wlfit's Avatar
Update - I didn't actually have to reconnect them but I squeezed the connectors a bit under the passenger seat and the error went away!
Give this a try first, before you take it to the dealer and they charge you $75 bucks for a diagnostic with no solution.
Old Jun 19, 2012 | 02:15 PM
legal22's Avatar
I know this is an old post, but I'm having the same issue now. Since I am definitely not mechanically inclined, what does it look like? Thanks!
Old Jun 19, 2012 | 02:46 PM
wlfit's Avatar
There are a number of wire harnesses clipped together. I'm not entirely sure exactly which one it was. I believe the clip was white.
Just look/feel around and try to tighten all of the ones you find.
Old Jun 20, 2012 | 02:07 PM
legal22's Avatar
wlfit: Great!! Thank you so much! I'll try it!
Old Jun 21, 2012 | 01:48 PM
legal22's Avatar
wlfit: That worked!!! Thanks so much!
Old Mar 25, 2015 | 05:46 PM
nattyb's Avatar
Just worked in a GD 09
Old post I know but..I just did a seat swap and had an error but it ended up being the connection. It reset itself no problem once I squeezed the connector tighter.
upaddZ
Jul 1, 2016 11:37 PM
m_x
Sep 26, 2014 03:53 PM
HB1320
Feb 27, 2014 07:43 PM
lovelyfit
Mar 27, 2009 10:22 PM
07TaffetaFit
Jul 31, 2006 01:43 PM
