Hatch Won't Unlock
Old Aug 26, 2011 | 03:07 AM
NHB_Fit_07's Avatar
Hatch Won't Unlock
I have an 07 Sport, and the hatch will not unlock when I use the keyless entry or the unlock switch inside the car. There is no key hole in the back so I cannot put anything back there with having to through it over the back seat . Anyone else have an issue such as this one?
Old Aug 26, 2011 | 05:37 PM
Jensen Healy's Avatar
Did you try changing the battery in your remote key fob?
Old Aug 26, 2011 | 06:42 PM
NHB_Fit_07's Avatar
Yea, tried both keys I had after replacing the battery, still a no go =/
Old Aug 26, 2011 | 07:57 PM
Rob22315's Avatar
Sounds like the solenoid in the hatch which operates the lock has gone bad. That or the wiring.
Old Aug 26, 2011 | 09:09 PM
spreadhead's Avatar
Until you get this fixed you can unlock the hatch from inside the car. There is a rubber plug on the inside the hatch. Remove this and move a lever inside to unlock hatch. It's all explained in the manual.
Old Nov 7, 2011 | 07:43 PM
traugh's Avatar
Didn't work for me. Move it and something went clattering to the bottom of the door.
Flyboybob
Jun 26, 2022 09:15 AM
headrec
Apr 11, 2019 10:03 PM
tvmax
Jun 19, 2016 12:54 PM
Fitskaroo
Apr 27, 2016 09:24 AM
Foots
Dec 7, 2012 08:25 PM
