Problem with Emergency brake sensor, e-brake cable? Not sure need help :(
Old Dec 2, 2011 | 11:46 PM
ivanjm422's Avatar
Question Problem with Emergency brake sensor, e-brake cable? Not sure need help :(
I picked up my tein s techs today from the shop, I was happily driving away when all of a sudden, the brake light turns on and it starts beeping. I check my e-brake and it's down, but the light and beeping is consistent. I pull over to the side and wiggle the e-brake handle up and down lightly and I see the light twitching going on and off every time I wiggle the e-brake handle. As I start driving off again, I notice that it's really really loose, and that the vibration of the car is causing the light to go on and off. Although it says the e-brake is on, it's not, because when I put it in drive, the car slowly moves without gas, as appose to with the ebrake on, the car wouldn't move at all unless I press on the gas. Any ideas of what it is before I head to the dealer and empty my wallet? I was so excited to get my s techs on my car but now I'm planning to wait so that the dealer doesn't give me some bullshit about how the spring caused the problem.
Old Dec 3, 2011 | 02:08 AM
Hootie's Avatar
My motto, "If its under warranty its the dealer's problem."
Having lowering springs on the car will not cause a dealer to completely void your warranty. The Magnuson-Moss Warranty Act prevents these and requires the dealer to prove that insert part or modification has caused the malfunction before a normally warrantied repair is voided. Example: Claiming window tint blew your engine isn't a legit cause, warranty still valid. On the other had, turbocharging the engine and it blowing will void your warranty on the engine (as well as drive-train).
If you want to try diagnosing it your self, I'd start by removing the center console, checking if anything is loose regarding the e-brake wiring and then go from there.
Old Dec 3, 2011 | 02:33 AM
ivanjm422's Avatar
Well I guess I'm off to the dealer first thing Sunday morning, possibly tomorrow after work. I just hate dealing with having to wiggle the damn e-brake just so it can shut up. Thanks for the info! And one last thing, anyone know if tein s tech springs are installed with the words and logos reading upside down or rightside up?
Old Dec 3, 2011 | 06:19 PM
Carbuff2's Avatar
Before you go "nuts" looking at the E-brake switch, have a look at the brake fluid reservoir.
If it is low you may just have to top it up a bit.
Low fluid can turn on the BRAKE lamp.
PS: If it has been more than two or three years since you replaced the brake fluid (and clutch fluid, if equipped), DO IT.
Old Dec 3, 2011 | 06:42 PM
ivanjm422's Avatar
Hmmmm, never thought of that. I'll check that out right now, but it seems to be some sort of sensor, I just punched the ebrake handle and the brake light turned off, and whenever I hit little bumps it turns off and on, so if that's any help...?
Old Dec 3, 2011 | 08:59 PM
Krimson_Cardnal's Avatar
Nothing more to be said.
honestrands
Oct 15, 2021 10:53 AM
chinkyy
Mar 4, 2013 10:37 AM
hockeymusic
Nov 2, 2011 09:51 AM
Sera
Mar 19, 2007 12:22 AM
Fit of RAGE
Jan 31, 2007 09:34 PM
