Grinding / Rattling noise when I come to a stop
Old Apr 9, 2013 | 10:13 PM
eddyksurfer's Avatar
Question Grinding / Rattling noise when I come to a stop
So I have noticed that whenever I come to a stop I can hear a rattling / grinding noise under the hood. However when I completly stop the sound goes away. I can only hear it when I slow down about 5mph to 0mph then the sound dissapears as the car comes to a stop. Ive stopped in Neutral and drive and the grinding noise continues. Any advice?
Old Apr 10, 2013 | 12:38 AM
MTLian's Avatar
My first guess would be that your brake pads are worn down to the squeal bar and that your rotors might be worn. A new set of rotors and pads sould only set you back about 150$. Does it happen when you apply the brake or even when coming to a rolling stop?
Old Apr 10, 2013 | 02:07 AM
loudbang's Avatar
^^^^ my bet also
Old Apr 10, 2013 | 10:56 AM
TW Calvin's Avatar
This sounds like your transmission.
Old Apr 10, 2013 | 10:08 PM
It does it whether or not I apply my brakes. It only rattles and grinds when I stop or go. Sounds like there is something loose but I dont know where from.
Old Apr 19, 2013 | 06:08 PM
Jonny_405's Avatar
loose exhaust bolt(s)? Had a rattle on my 08 fit under certain rpms. Still under warranty at the time, dealer thought cat was bad, replaced it, no fix, after closer inspection they found a couple bolts on the exhaust manifold heat shield had worked loose.
rock/pebble stuck in between back side of rotor and metal shield? this produces a loud scraping/grinding noise at low speeds. obviously only when the wheels turning will it be noisy.
Old Apr 19, 2013 | 11:15 PM
MTLian's Avatar
If you feel it in your steering wheel it could be a cracked engine mount?
Old Apr 20, 2013 | 12:21 AM
still grinding
sot from 1-5 mph I hear the grinding noise then it dissaperas abobe 5 mph. It does it when I come to a stop from 5mph to a full tstop then it stops grinding. Whether or not my brakes are applied or not it grinds and rattles. Whether in drive or neutral it rattles. The transmission seems to run fine. Im going to check the exhaust manifold bolts to see if that is the culprit or not.
Old Apr 20, 2013 | 11:20 AM
JeffChap's Avatar
Brake pads. They are in contact with the rotors even when you are not applying any pressure to the pedal.
Old Apr 21, 2013 | 09:51 PM
but its more of a rattling sound like theres something loose......are there common areas that come loose on the fit?
vonshu
Apr 2, 2019 09:48 AM
UnicycleWheelie
Jan 4, 2015 01:07 AM
msoulier
Jul 22, 2011 11:22 AM
hqly
Jun 30, 2011 08:34 AM
bittermelon
Mar 27, 2008 03:46 AM
