New Battery
Old Aug 22, 2013 | 02:32 PM
Antpwny's Avatar
New Battery
It seems that it's come to the time where I need a new battery (cold starts are not occurring in 60 degree weather). I was looking around and found a bunch of conflicting information. Does anyone know of a battery I can replace the car with without having to buy a mounting bracket or relocation kit? Something that will fit in the OEM position?
Any help would help.
Old Aug 22, 2013 | 02:48 PM
Antpwny's Avatar
I've seen a lot of posts about this battery: Odyssey PC 680 Battery
But no one has said anything of it fitting without modifications. Everyone has the relocation kit but I clearly wouldn't need it since I'm stock.
Old Aug 22, 2013 | 02:53 PM
BurntZ's Avatar
again, what model year are you talking about?? Apparently the first generation (2007-8) does not require any modification so people are going and installing the better 51R battery (available at Costco and elsewhere)
Old Aug 22, 2013 | 06:38 PM
13fit's Avatar
51R battery still works in GE8, just needs a bit of shaving done to intake box.
Much easier to simply install an aftermarket intake at same time.
Else you need to cut some of the plastic around the positive cables and flatten the wires. What I mean is the plastic casing of the terminal and fuse holder is cast in an L shape. Removing the cable guiding legs allows it to lay flat so you can install directly to 51R battery
Old Aug 22, 2013 | 10:19 PM
Antpwny's Avatar
First gen, sorry I wasn't clear just didn't think I had to bring it up because I posted in the 1st gen forum. Alright I will go to Costco and ask for the 51r.
Old Aug 23, 2013 | 12:04 AM
Brain Champagne's Avatar
Ask? Have you been to a Costco?
sh00k
May 25, 2013 04:14 PM
HKDM808
Oct 18, 2012 06:24 PM
sy11580
39
Jul 2, 2009 04:00 PM
redrumm
36
Sep 28, 2007 02:34 AM
c_kubie@yahoo.com
Jul 19, 2005 09:31 PM
