gd3 manual tranny question
Old Nov 6, 2013 | 01:08 AM
Nvillegas's Avatar
hey guys, i i owned a 08 fit and im the 2nd owner after less than a year of owning it i noticed some noise through my tranny like a whirring sound and i have a feeing it is one of the bearings not sure which one but whenever i disengaged the clutch (pedal depressed) it goes out..someone told me its either pilot bearing or input shaft bearing,im planning to have my clutch replace in a few months so im thinking its better idea to do everything while im in there,question is..lets say it is the bearings that making those noises is worth it to replace everything needs to be replaced or just get a used low mileage tranny?..make everything easier not sure tho if used trannys will last..and lastly do shops charge separately when they pull out your tranny?..i mean is it a different charge doing the clutch and tranny? thanks..
Old Nov 6, 2013 | 10:12 AM
Marrk's Avatar
If I recall correctly, I had that noise at approx 27k mi., and the dealer replaced (under warranty) the pilot bearing. I think they also replaced the throw-out bearing, just because they had everything open and it was easy to do as a precaution.
Sorry my memory is imprecise at the moment. The morning coffee hasn't kicked in yet.
Old Nov 7, 2013 | 06:05 PM
apexanimal's Avatar
So would it be prudent to replace the pilot bearing while replacing the clutch?
Is it relatively accessible part to replace?
Old Nov 7, 2013 | 07:11 PM
Marrk's Avatar
I do not know. However, the rule of thumb is that, on a job that requires a lot of disassembling, you might as well replace whatever is likely to go next, so that you don't have to tear into the engine-tranny all over again any time soon. The more you teardown-replace-reassemble, the more money you spend on labor.
Old Nov 7, 2013 | 09:36 PM
Nvillegas's Avatar
mine doesnt come with factory warranty anymore neither extended warranty,so ima have to pay it cash..how would i know its the pilot bearing? is it the same sound as input shaft going out?..dealership asking 2000 for clutch replacement,im pretty sure if they will open the tranny it will cost more..do you guys have any other shop that you can recommend?..i heard of AAMCO and LEON's but not sure how the labor quality will be..
omega505
Nov 29, 2017 11:56 AM
TroyGgd3
Oct 26, 2016 08:30 AM
carrier
Jul 1, 2016 07:43 PM
viperpit07
Nov 8, 2015 09:52 PM
trinisir
May 11, 2015 08:47 AM
