Front jacking point
Old Nov 18, 2013 | 06:08 AM
Hondicious's Avatar
Front jacking point
Front jacking point, do people use the engine cross-member (shown in green below)?
Old Nov 18, 2013 | 07:51 PM
Juan2Six's Avatar
I have... with a floor jack after I found this:
Lift and Support Points
Old Nov 19, 2013 | 10:15 AM
Marrk's Avatar
Yes, that is one of the correct jacking points.
Old Nov 19, 2013 | 03:11 PM
eddiec168's Avatar
I hate that it's so far back.
Old Nov 20, 2013 | 02:22 PM
Hondicious's Avatar
Ok thanks.
I have the haynes manual and it suggests the radiator cross member but it looks too wimpy to support the whole of the front end, plus you would need to remove the splash guard with 10 or so clips/screws.
I have homemade ramps, so I can use these to get access to the engine cross member.
Old Nov 20, 2013 | 02:54 PM
eddiec168's Avatar
Ok thanks.
That's actually how my parents Corolla and Camry does it. But it doesn't look reinforced in the Fit. I don't trust it.
Old Nov 20, 2013 | 06:30 PM
Marrk's Avatar
Don't use that location for jacking.
Old Nov 22, 2013 | 12:22 AM
MTLian's Avatar
Correct! That's the point I use when I need to put my front wheels on jack stands. I drive up on some 2x4s (scrap wood) and then get my trolley jack under there. I actually wedge a piece of wood between the jack and that part for two reasons 1) that part can bend and get scraped by the "cup end" of my hydraulic jack and 2) even on the blocks, it is near impossible to get any leverage since the very small lever of the jack is well underneath the front bumper cover. I've been searching for an extension bar for that exact purpose! If you can find a good deal on a low profile jack I say go for it, just make sure it jacks up high enough for your needs.
Old Nov 22, 2013 | 06:01 PM
Hondicious's Avatar
Originally Posted by MTLian
...that part can bend...
Shouldn't deform as it bears the weight of the car's front end in normal use.
...I actually wedge a piece of wood between the jack and that part ...
I don't think I'll be doing that. The centre lug outlined in green projects 10 to 15 mm out from the main cross member. So I think there would be a real possibility of slippage. I'll just put a thick piece of cloth in the jack cup to stop metal on metal damage.
Old Nov 22, 2013 | 07:49 PM
MTLian's Avatar
Nope, it'll bend. I bent/dented mine with the cup end of my jack. Since the "cup end" of my jack is not large enough to contain the whole square, I think there is actually more chance of slippage (for me) without the use of the scrap wood. I make sure the piece of 2x4 is well positioned before actually lifting the car. Also, the cup end teeth of the jack actually sink into the wood, providing good stability on that side. Anyway, I just raise the car high enough to place my jack stands and lower the jack right after. Others have mentioned using a hockey puck which is probably a good alternative.
Good luck and be safe.
Old Nov 25, 2013 | 12:09 PM
Hondicious's Avatar
Ok thanks for the info. I'll see if I can't make a custom moud out of a hockey puck and post back with the results.
jh62
Nov 15, 2017 09:08 PM
SilverEX15
May 21, 2017 10:30 PM
knm345
May 19, 2013 01:45 PM
knm345
Apr 1, 2013 07:32 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
