08 Fit won't start( not a battery issue)
Old Apr 2, 2014 | 09:25 AM
singlecam screamer's Avatar
Hey guys I just wanted to share an issue I ran into with my Fit this last week. So I go to start my car in the morning and it turns on for a second and then it shut off and wouldn't restart. The car would turn over but I didn't hear the fuel pump kicking on, so checked the fuses and looked at the relay and they seemed ok. I pulled the fuel pump out and where the connector goes plugged in had a singed hole through one of the legs. I looked at the bottom if the connector and it seemed it shorted out and molded the pigtail harness onto the connector. I ordered a new pump assembly since the plastic container was the issue and I had to buy the fuel pump assembly module $300. I also got a new relay just in case and put the pump in and the car started right up. I am sharing this with you guys cause I have never had any issues with the pump or car, with the infrequent hesitation here and there but I attributed it to the coil packs . Hope this helps.
BLP
Apr 18, 2021 05:20 PM
Ridza
May 6, 2016 05:48 AM
mikestvn
Dec 15, 2015 01:41 PM
Tenuki Kyle Gray
Oct 14, 2014 08:34 PM
timsfit
Nov 13, 2011 04:55 PM
