How to remove the tow hook cover?
Old May 28, 2014 | 11:05 PM
MTLian's Avatar
I'll be hauling a canoe this summer and I'd like to use the front tow hook as an additional anchor point (not a principal point, the canoe will be mainly held to the Thule rack). I tried remove the tow hook cover but gave up after about 10 minutes of pushing and pulling. I don't want to break the cover or scratch my paint with a sharp object. I even tried looking in the service manual but there is no explanation!
What's the secret? Do you have to twist it or what?
Old May 28, 2014 | 11:13 PM
SieGunso's Avatar
slide something flat and strong into the slight cutout on the bottom of the cover and carefully pry outwards
Old May 29, 2014 | 06:47 PM
myfoxmystere's Avatar
Your tire jack toolkit has a pry bar/crank handle with a spoon tip. It's a multipurpose tool used to pry off the wheel covers on a Fit Base, and a tool to pry open the cover where the hook installs on the front bumper, and tighten down the tow loop. The tool is also used to access the taillight assembly as well.
Old May 29, 2014 | 11:16 PM
MTLian's Avatar
Thanks for the responses guys! +rep
cgwaters
Apr 20, 2016 10:48 AM
morgantruce
Oct 6, 2014 10:10 AM
Clancystl
Nov 19, 2013 09:38 AM
Sloto200
May 7, 2008 10:43 AM
switchbrdopr
May 11, 2006 10:08 PM
