Hesitation/hiccup when accelerating
Old Oct 29, 2014 | 01:31 AM
averona's Avatar
'07 sport manual with 116,000 miles.
Accelerating between 2nd and 5th gears, when throttle pressed, car hesitates or hiccups. I've changed air filter and done 2 fuel system cleaning services. It gets a little better, but problem still exists.
What in the world could it be, thanks?
Old Oct 29, 2014 | 01:40 AM
john21031's Avatar
No offense, but sounds like you have a beginner's knowledge about cars (based on changing the air filter and cleaning the fuel system).
The cause of your problem could be very complex and I would suggest taking it to a mechanic.
The car needs to be connected to an OBDII scanner to read for possible trouble codes.
Multiple sensors will need to be ruled out (MAF, TPS, Engine - CTS, O2, CPS) as well as as fuel system checked for correct pressure. Engine compression test may need to be done. EGR system checked, etc.
You can start learning, can start throwing unrelated parts at it, or just take it for professional diagnostic and then shop for the best price on repair.
Good luck.
Old Oct 30, 2014 | 10:11 PM
lakia5524's Avatar
i can say i bet its a coil pack or more mine went bad at 72 thousand and had intermittent stalling hesitation with no codes drove me crazy until i got the oem Hitachi coils my guess you could alway get four from advance auto parts they have 90 day warranty if it acts up after just refund and get your money back there are tons of people on here that have had this problem and coil pack seemed to be the issue
Old Oct 31, 2014 | 03:13 PM
Desmond Lamar MacRae's Avatar
I tend to agree with him and the other member. Take to Honda or where ever b4 wasting funds buying everything under the sun and still have this issue.
Old Nov 2, 2014 | 08:21 AM
averona's Avatar
Turns out it was egr valve sticking. Easy fix?
Good luck.
Old Nov 2, 2014 | 09:47 AM
Perrenoud Fit's Avatar
its easy if ya have basic tools and the GD3 is easy to get to.
i'd use 2+2 carb cleaner too.
danielmorrison
Jan 31, 2019 12:55 PM
prem.lorlamai
Dec 5, 2017 05:56 AM
timsfit
Nov 13, 2011 04:55 PM
michaelescalona21
Apr 16, 2011 05:16 PM
bleaubyou
Sep 11, 2009 12:31 AM
