2007 Fit Base Keyless Workaround?
Old Oct 30, 2014 | 10:55 AM
PaceP's Avatar
Question 2007 Fit Base Keyless Workaround?
Hellooooo Freaks!
First post here, however I've been reading quite a bit lately!
Situation:
2007 Honda Fit Base. Want to add keyless. Factory Keyless (08E60-SLN-100) has been discontinued and I cannot locate one anywhere!
SO- I have been scouring the web to look for a solution. What I've found is that people have been upgrading other vehicles (Civics, Elements, CRVs) by adding a new keyless receiver from a CRV (38385-S9A-A01) and then utilizing the appropriate keyfob that is synced with that receiver.
DIY: Upgrading stock keyless entry to Accord / CR-V style fob-head key - Honda Civic Forum
Obviously this isn't optimal, however with the original kit unavailable, it seems that I'm at the end of my options so I figured I would get creative.
The problem I see is that the original kit comes with a small harness that can plug into the fuse box to install the receiver. I know that the CRV receivers are readily available for around $50, however I cannot find the harness that gets it into the Fit.
#7 in the picture here:
http://www.myhondapartsstore.com/myh...N701_XEL03.png
Am I just treading water on this? Would this even be a viable option, or am I stuck going aftermarket?
I hope my above explanation of idea was clear. If not, I'm glad to reiterate. Thanks in advance!
-Pace P.
Old Oct 30, 2014 | 12:59 PM
DWils's Avatar
Someone else on here has confirmed that the part still exists, the number has changed though. The last three digits are 300 instead of 100. There are a few threads floating around that have been bumped relatively recently (within the last month or two) with that information.
Old Oct 30, 2014 | 01:02 PM
PaceP's Avatar
Thanks for the reply! I have tried searching the 'new' part number to no avail... I'm wondering why it doesn't show up anywhere?
My friend at Honda dealership searched it, and it's not listed in their system. Did you have any recommendations on where to track that down? Thanks!
Old Jun 23, 2015 | 08:51 PM
ndanielle1968's Avatar
Talking Keyless Entry Part # 08E60-SLN-100
I've been checking on this same issue. I have a 2008 Base Honda Fit and want to make it a keyless entry.
I haven't had any trouble finding the part when searching for Honda OEM part websites - as of now I've seen it sold for $105 - $150ish.
08E60-SLN-100
https://www.hondapartsonline.net/par...catalogid=5264
The instructions I've found are here -
http://www.bernardiparts.com/Images/...m_AII37484.pdf
I haven't purchased this item yet, but I'm definitely going to go ahead and do so - it's absolutely worth it to me.
Old Jul 8, 2015 | 03:04 PM
hondafitty's Avatar
Exclamation
08E60-SLN-100
The problem is once you go to purchase the parts, they are out of stock. I've "purchased" from two separate sites and then get an email and refund same day saying the part is out of stock.
Still searching for an answer. Please bump, reply anyone who has figured this out.
Old Jul 16, 2015 | 02:53 PM
ConradSch's Avatar
Agreed, with the out of stock. I ordered one online, and got a notice this morning saying that the part was out of stock. Going to try and call the dealership now - luckily, I'm in Canada.
Old Jul 16, 2015 | 03:05 PM
ConradSch's Avatar
Well, that is interesting. The dealer has offered to re-tumble my driver door for 35 dollars (with me just handing him the tumbler). They have the part, and it's 216+tax, with the same part number mentioned above 08E60-SLN-300. FOr those folks in Calgary, it's T&T honda.
Old Jul 19, 2017 | 11:41 AM
PaceP's Avatar
Bumping this thread back up. I found a kit, but am going to sell it as I'm getting into a new Fit. Be on the lookout for the OEM keyless kit for sale!
Old Apr 30, 2018 | 09:41 PM
vic831's Avatar
Keyless aftemarket
I added a generic simple keyless kit $12.00 off eBay wired to pw door master switch in drivers door. Can only lock and unlock all 4 doors and hatch at same time but it works for me.
Captain Slow
Feb 22, 2022 04:38 PM
cuban8
Aug 15, 2018 09:13 AM
thorton0
Apr 30, 2018 09:36 PM
PaceP
Jul 20, 2017 01:41 PM
madxpinklady
Nov 17, 2013 08:48 AM
