Acceleration issue
Old Nov 18, 2014 | 07:43 PM
georgi6's Avatar
Acceleration issue
2007 Honda fit
When I am pulling off, barely pressing the gas pedal, the car jumps and accelerates rapidly. I thought the pedal is very sensitive, but at about 20 mph it keeps accelerating but very slow - I can hear the engine revolutions getting higher. At speed 50-60 mph, when overtaking another car, it accelerates normally. Is there some adjustment - the transmission or something else?
Old Nov 18, 2014 | 08:35 PM
Lance's Avatar
Did...U....
Check the trans fluid level?
Old Nov 18, 2014 | 09:29 PM
georgi6's Avatar
Transmission fluid level is OK.
Old Nov 18, 2014 | 09:50 PM
Hootie's Avatar
How many miles?
How long has this been going on?
Does this happen only after cold start, after hitting operating temp, or intermittently at any time period?
Is the Check Engine Light on? If yes, how long and have you checked the codes?
Did you check the ATF as per Honda's steps? (Start engine, let idle till fans engage twice, shut down engine and check level)
Old Nov 18, 2014 | 10:51 PM
georgi6's Avatar
How many miles? - 38000
How long has this been going on? - I bought it 2 months ago
Does this happen only after cold start, after hitting operating temp, or intermittently at any time period? - at any time
Is the Check Engine Light on? - NO - If yes, how long and have you checked the codes?
Did you check the ATF as per Honda's steps? (Start engine, let idle till fans engage twice, shut down engine and check level) - yes i did but after fan engage shut off engine and 30-40 sec after it checked the level
bwb
Jul 19, 2025 01:56 PM
phenoyz
Apr 14, 2015 10:16 AM
Joe Dirt
Dec 26, 2014 10:37 PM
shivic
Mar 30, 2014 01:55 PM
gmac
Mar 2, 2012 01:21 PM
