Stalling when cold and other problems
Old Jan 18, 2015 | 05:55 PM
Bigger On The Inside's Avatar
2008 Fit Sport 120k
Maybe someone knows what's going on with my wife's Fit. It refuses to drive when cold, it stalls when transmission is switched to drive or reverse. After it gets hot, it seems to run fine. No apparent performance issues. Also, when first started the exhaust has a sulfur smell.
Thanks for your time,
E
Old Jan 19, 2015 | 07:38 AM
Carbuff2's Avatar
Need Maintenance History:
Plugs Changed?
Valve Adjustments?
Plug Coils replaced?
Throttle Body cleaning?
Old Jan 19, 2015 | 03:32 PM
bargainguy's Avatar
Also EGR valve....
Old Jan 20, 2015 | 02:19 PM
Doug Just Doug's Avatar
Clogged catalytic converter? (The forum inserted that hyperlink, not me.)
Old Jan 20, 2015 | 07:46 PM
samcl9's Avatar
Pretty sure your valves need to be adjusted. Heres a DIY DIY adjusting valve clearences GD - Honda Fit Forums
Old Jan 25, 2015 | 11:20 AM
dajonga's Avatar
Mine did the same exact thing. Your valves need to be adjusted.
Mxzking
Apr 29, 2018 10:25 PM
chubbys2k
Nov 2, 2016 07:55 PM
frank438
Jul 12, 2016 11:14 AM
hollyh
Mar 11, 2016 10:43 PM
mkane
Jun 5, 2013 04:44 AM
