Radio from a junkyard
Old Nov 15, 2015 | 11:28 AM
simo10's Avatar
Hello,
I'm a soon to be owner of a Fit that's a bit of a project.
The stereo LCD is bad and I want to replace it with one from a junkyard (or ebay)
I know that the stereos require a code to enable them. Will this be a problem with a junkyard radio? Where do I get the code?
Thanks
Old Nov 15, 2015 | 11:44 AM
ezone's Avatar
What year is the car?
check glovebox for a radio code card or sticker before yanking it out
ask seller for the unlock code before buying
or
obtain radio serial number from the sticker or through the 'button dance' once it's hooked up,
then contact your dealer for the unlock code
or use Hondas radio code website to get unlock code
https://radio-navicode.honda.com/
Old Nov 15, 2015 | 12:01 PM
simo10's Avatar
It's a 2007
So I shouldn't have any issues even if the unlock code is not in the car?
Old Nov 15, 2015 | 01:03 PM
ezone's Avatar
Originally Posted by simo10
It's a 2007
No prob. The unlock code can be obtained using the serial number on the radio, it doesn't matter what car it's in.
The previous link describes how to get the SN electronically too.
Old Nov 15, 2015 | 04:44 PM
xxryu139xx's Avatar
im sure someone here with an aftermarket radio has an oem one lying around. if u had a GE8 id hook u up.
Old Nov 21, 2015 | 11:07 PM
jmsplitfyre's Avatar
Also another way to pull up your serial number is to press and hold button 1 & 6 simultaneously. Then either you can retrieve the radio code online or you can go to your closest Honda dealer to get it.
Old Nov 22, 2015 | 12:25 PM
pcrussell50's Avatar
I did that very thing. I bought a replacement OEM radio from a junkyard that sells over ebay. Obviously I needed the radio code. But this junkyard was smart and professional, and included the VIN and the year make model, of the Fit the radio came out of, so when I went to Honda's web site, I plugged that info in, and got the code immediately. Smooth as silk. And since it came out of a Fit Sport (my fit is not a Sport, just a plain 5MT), the radio had AUX capability, so I wired in an AUX plug and now I have factory AUX. Loving it.
-Peter
crash001
Jun 28, 2024 07:54 AM
john21031
Feb 23, 2020 06:19 PM
Mister Coffee
Feb 7, 2019 06:00 PM
mahout
Jun 4, 2011 08:17 AM
Lideusz09
Oct 9, 2009 05:41 PM
