07 Fit Sport (Wheel/Tire Question)
Old Jan 23, 2016 | 09:47 PM
15x7 +41 RPF1 are a GREAT affordable setup for a GD3.
Old Jan 23, 2016 | 10:08 PM
tommyarmour's Avatar
Originally Posted by Hootie
You might get a better deal on those two wheels from Good-Win-Racing. They have some specials currently going on that are either discounts on the wheels or free shipping.
Here's the listing for the '90 to '05 Miata, which also has 4x100 PCD (lug pattern). You can toggle from wheel spec to wheel spec to help get rid of options that will not work for you.
Miata Wheels - Wheels - Mazda Performance Parts
Here's a link to one of the multiple RPF1 listings, this one is a silver 15x7 +41 with free shipping at $184.
ENKEI RPF1, 41mm offset Silver for Miata 1990-2000, 15x7
But then again we are back to a offset of +41 when I need +55mm on the RPF1.
I did find the Honda 16" Alloy Wheels HFP I believe that are for the FIT +55 offset. That is the only wheel I could find with the +55 offset 15x6.5. I contacted TireRack through email. Asking all the questions i had. Hopefully they can point me to the right direction or figure out a way to get the offset to match. My Shaving the wheel or spacing it, whatever needs to be done to do it right.
Old Jan 23, 2016 | 11:28 PM
Your offset doesn't need to be exactly the same as stock.
Old Jan 24, 2016 | 01:32 PM
Please explain why, and what wheels will work? What offsets are safe? If +55mm is what's on the OEM wheel why would +41mm offset be ok? I understand lots of wheels are made differently and on one wheel a offset may work, then on another wheel with the same offset it will rub. Its crazy more wheel manufacturers don't have offsets to match the Honda Fit. Jesus it a HONDA. Of course I've read many other fit owners have used different offsets. I've also read an equal amount of threads that have rubbing issues now. On Monday I'm going to the Honda dealership, and to Les Shwab to get some answers. If I'm going to spend over 1k on wheels and tires I don't want problems. Just to look or handle a little better.
If I go with the Enkei RPF1's I am doing it for handling(lightest wheels), and will probably go with Racing Coil-overs in the near future.
I'm also 2nd guessing pimping a 2007 1st gen fit. I bought the car 4-5 months ago(45,000 original miles), I had the windows tinted immediately and installed Android Auto(Pioneer 4100nex). Now I was thinking Wheel/suspension. CAI, Exhaust, Performance chip, maybe headers. And thats it. DONE Maybe a K20 swap. LOL just kidding
Old Jan 24, 2016 | 01:51 PM
For the last few months I thought GD1, GD2, GD3, all those had to do with generations of fits. Today I found out they are DriveTrain Layouts. LOL
It's the different types of Fit/Jazz available:
GD1 = 1.3L FF
GD2 = 1.3L 4WD
GD3 = 1.5L FF
GD4 = 1.5L 4WD
GD5 = 1.2L FF
GD6 = 1.3L FF (seden)
GD7 = 1.3L 4WD (seden)
GD8 = 1.5L FF (seden)
GD9 = 1.5L 4WD (seden)
So my 2007 Honda Fit Sport is a GD3. As are most FITS for all years, except the GD9 sedan. Interesting
Old Feb 29, 2016 | 02:12 PM
The Choobs's Avatar
I've installed 16s and even 17s before. Don't wander to far from the offset. About the width 6.5 to 7jj is alright.
Here's a neat tip to decide what kind of tyres to get. Just use a diameter calculator, clock in the size and just see how different the the overall diameter.
https://tiresize.com/calculator/
The bigger it gets, the taller your car gets. You may need lowering springs if you go real big so your car won't look awkwardly tall. Try to keep it lower than 24 inches in total diameter and it won't look too dorky on stock suspensions. Of course wider, and low profile tires do contribute to better handling.
Recently i dropped my 17s (205/140/17) Enkei. Needs lowering springs to look neater.
I finally found a nice piece of Japan Mugen NR 15s (6.5j) and use 195/55/15 now. Working like charm.
Old Mar 1, 2016 | 07:44 PM
dwtaylorpdx's Avatar
Competition Car Suspension: Design, Construction, Tuning Hardcover – November 13, 1999 Amazon..
When you change offset it affect bump steer and Ackerman angles.. Small offsets, +- say a half inch don't matter much on the street.
I have used 1 offset wheel to fix handling problems on road race cars before.. Not my favorite way but it can work.
Old Mar 10, 2016 | 04:22 AM
craigquakertown's Avatar
These are 16's what size tire would I need? Should I look for a wheel with a offset closer to +38. I don't really understand the offset too much. I want good looks so I figured going to 16" would be safe. But with the different offsets It's gets a little confusing. I also going to get a good 50-75k warranty tires. Just need a good safe size to shoot for:
Here is a 15" Wheel closer to stock wondering if I would just want to shoot with the same tire size as stock for wheels like these:
Thanks for the help guys!!!!
i would just stick with the original offset and just adjust the profile
Old Mar 10, 2016 | 01:45 PM
FWIW my stock 07 wheels are stamped 55 offset on the exterior side between the spokes.
as long as the overall height, overall tire width, and offset is the same handling will only change as far as having a lower profile tire affects it.
To understand why changing the offset can affect handling, look up bump steer and Ackerman angle.
blvsphemy
Jan 9, 2020 12:13 AM
Payo
13
Jul 15, 2019 11:51 AM
Previc93
Mar 6, 2013 01:44 AM
Crawly
Mar 12, 2009 08:42 PM
Scaldy
Dec 24, 2008 11:00 PM
