Honda Fit 04' Transmission Failure
Old Mar 7, 2016 | 01:03 PM
HondaCyprus's Avatar
Exclamation Honda Fit 04' Transmission Failure
Hi
As the title says i have a Honda Fit (03-04' im not sure) with 107.000khm on it. It is second hand and i don't know whether the previous owner ever changed the ATF or not. Today as i was driving on the highway transmission stopped working. Engine works but car doesnt move neither front nor back. No alarm lamps on whatsoever. My question is if i order through my mechanic ATF fluid now will it help revive the gearbox? I stopped immediately if that helps.
Sorry for my noob question or if this is posted on the wrong thread.
Thank you for your time
Alex
Old Mar 7, 2016 | 02:35 PM
dwtaylorpdx's Avatar
Low fluid.
or
Failed transmission solenoids.
or
Wiring to tranny..
or
Failed Pump on input of transmission.
There are more possibilities but these are the first ones I'd troubleshoot.
Old Mar 22, 2016 | 09:21 PM
tony_2018's Avatar
Hmm...no CEL's??
Old Mar 24, 2016 | 07:21 AM
07FitSprt's Avatar
My guess would be something with the linkage? if there is anything internally wrong it would throw some sort of code. The ecu usually monitors shaft speeds and solenoid voltages etc. If it sees something out of whack it usually would set a code.
ChuckDustin
Apr 24, 2019 08:24 PM
CorkumBorkum
Nov 29, 2018 07:26 PM
2007Fit5AT
Feb 6, 2018 02:44 PM
Dytkrjb
Feb 22, 2015 04:51 PM
DaviT
May 4, 2005 04:44 PM
