Adjustable steering does not lock well.
Old Dec 5, 2016 | 07:29 AM
EdRedSled's Avatar
Hello all, noob, but I did search..
2008 Fit S with 5 speed. The adjustable steering wheel is locked in place but still moves (less that if it were unlocked).
I don't normally need to adjust it, but my 6'5" son drove the car last week, so I suspect he did adjust it. Regardless, the wheel is moving around even though the lever under the wheel is locked down.
This is not sloppy steering rack as far as I can tell as the car drives fine. Its not the steering wheel lock (when the key is removed).
Anyone else have this experience? I can't find any write ups, but perhaps I am searching the wrong keywords. Much appreciated.
Old Dec 5, 2016 | 09:53 AM
doctor J's Avatar
Steering column assembly
Remove column cover and check the spring on the lever.
The upper column part is snapped into lower part and is fragile. You need to use body panel tool or sharp polished flat screwdriver to pull it up. The screws are attaching lower part only to the column
Attached Thumbnails Adjustable steering does not lock well.-80-22140_hfit_g0188_0dc94a6e28cc677cab36144bdcd397c6696db670.gif
Old Dec 5, 2016 | 10:39 AM
EdRedSled's Avatar
Thanks doctor j - will give it a try once we get some good weather.
If_It_Fits
Dec 30, 2018 02:28 AM
FitfulKenny
Dec 4, 2015 09:45 PM
CrystalFiveMT
Apr 2, 2011 06:35 AM
Brain Champagne
Feb 7, 2011 11:38 PM
stony
May 4, 2005 11:16 AM
