Just bought an 07 with P0172
Old Jul 9, 2018 | 10:29 AM
  #101
Tim1985's Avatar
Replaced all 4 injectors
replaced all 4 injectors could fix p0172 with system too rich.
Old Oct 27, 2024 | 02:47 AM
  #102
onionzzzzz's Avatar
P0172 Still Haunts me
Reviving the thread, thanks for much for all the informative posts. Finding this was shocking to me because I’m experiencing the same things and also tried the same things.
hoping the users are still frequenting the site!!!
sadly, all 4 new injectors and I still get this code (not as frequently as every 30kms or so). Sometimes longer sometimes less. Not OEM though, think I should try rock autos versions?
im totally stumped, anyone else have a solution for this?
PS Im turbo, and have a feeling it’s to do with the hks fcon mini. Drives perfectly and I get pretty good mileage still. Just pesky light comes on and ruins my day.
Old Oct 27, 2024 | 06:46 AM
  #103
Tim1985's Avatar
I changed my injectors works, you can try other things
Old Oct 27, 2024 | 05:08 PM
  #104
onionzzzzz's Avatar
thanks for that. I’ve already changed all 4 injectors with brand new ones. I’m waiting for new fuel sock as the existing one is pretty cruddy.
here’s a list of things I’ve changed
- New sparks oem
- New coilpacks hitachi
- New o2 sensor oem
- New PVC valve
- New fuel filter oem
- Valves adjusted
​​​​​​- Fuel pressure is at 55psi
- EGR is ok (clean)
- TB is ok (clean)
after that, will change all exhaust gaskets just incase it is leaky somewhere and report back. My o2 sensor is on the stock double walled front pipe now though due to turbo, I wonder if this can cause incorrect readings.
it’s weird because sometimes I can drive for 250kms+ without reaching the light (car does 6.5-7//L/100 km). Overall the car drives perfectly smoothly, no hesitations no sputters and no misfires. Light just decides to come on when I least expect it. 🙂‍↕️
thanks and sorry for long post.
Old Jul 13, 2025 | 11:27 PM
  #105
Edamame's Avatar
- New sparks oem
- New o2 sensor oem
- New PVC valve
- Valves adjusted
- EGR is ok (clean)
- TB is ok (clean)
Were you able to figure this out? I saw OP said changing the fuel injectors fixed their issue, but I changed mine and still get the code. I was thinking maybe fuel pressure regulator? But stumped tbh.
Old Jul 21, 2025 | 01:10 AM
  #106
onionzzzzz's Avatar
I was able to literally 2 days ago! I replaced my 3.8kpa FPR - and haven't go the light to come back since. I literally replaced every sensor and triple checked every vac line and seal before I decided to replace the FPR again (since it was within spec ~52psi (top end)).
I would try that first - very easy to do and inexpensive to try first before attacking the others. Goodluck!
JMR808
Jan 13, 2023 06:17 PM
georgi6
Apr 23, 2019 07:49 PM
Nakor
Jan 7, 2019 07:09 AM
BansheeScratch
Nov 14, 2011 09:56 PM
markielowski
Jan 2, 2011 03:08 PM
