2007 Fit Sport - Replacement Transponder Key Information
Old Mar 6, 2017 | 09:31 PM
Metadata's Avatar
I bought an 07 Fit Sport a few weeks ago and it only came with one key. This is what I have learned.
The 2007 and 2008 sport use different immobilizers but use the same frequency remote.
Only the RFID chips differ.
The 2007 uses an 8E glass chip while the 2008 uses the more common ID46 chip.
I purchased two keys from eBay (china seller) and the listing said the keys were specific to the 2007 Fit Sport w/ 8E chip.
I opened the keys that came from eBay and the keyless remote said " G8D-384H-A" but my original key says OUCG8D-380H-A. I feared that it would not work and programming would not be possible. I found instructions on programming the remote the same night and paired the remote keyless entry fine.
From what I gather, OUCG8D / G8D is the frequency, and 380/384 numbers identity how many buttons are on the remote. The remote I purchased has Lock + Unlock + Panic aka 2+1 button remote BUT it does have a pushable button for the Trunk release but is not functional as the remote casing does not have the exterior physical button.
I then went to a local locksmith to have the keys cut for $25 each and then $45 each for RFID pairing but he was not able to do it without telling me why. After numerous attempts, he gave up and I was on my way with two keys that would not start the car.
I found a second locksmith who has a 5* rating on yelp. He put my original key in his machine and it showed that the RFID tag is chip 8E. Cool. He then put in the eBay keys and immediately saw that the chip was ID46 and said they would not be able to pair the keys.
He had plenty of the ID46 chips but no 8E chips. I contacted the eBay seller and sent them a picture of the keys I received and he said they had sent me the wrong keys. They are sending me just the 8E replacement chips today which look different.
the ID46 chip looks like very tiny brick and the 8E looks like a medicine pill made of glass.
As of today, I am waiting for the replacement chips and will be visiting the locksmith again.
The second locksmith charges $60 to program up to three transponder chips, wheres the first guy charges $45 each.
Also, there are two ways to program keys. The OEM way is to PAIR the key to the vehicle, and the "aftermarket" way is to CLONE the original working key, to the new ones.
I believe that the locksmith can do it both ways depending on your situation.
UPDATE 03/22/17
Comparison. ID46 vs ID8E.
I am going to the locksmith to have the chips programmed to the car later today.
UPDATE 03/18/17
The 8E chips came. Here is what they look like.
Old Mar 6, 2017 | 10:55 PM
ezone's Avatar
Good info, thanks!
I wish our shop had something that could ID the various RFID chips in our inventory of keys.
Old Mar 10, 2017 | 04:44 PM
fittenmittens's Avatar
Can you PM me the seller/item on ebay? Thanks!
Old Mar 10, 2017 | 05:58 PM
dwtaylorpdx's Avatar
As far as I've been able to find,, for an 07 the only thing that can pair a new non cloned key is the honda dealer computer.. so cloning is the only option without the replacement of the receiver in the steering column and a new set of keys..
Old Mar 11, 2017 | 02:10 PM
Metadata's Avatar
In eBay, search for Honda fit 8e key. There are some US sellers but they charge about $30. If you aren't in a rush, the ones that come from China are $11-12
Old Mar 11, 2017 | 02:11 PM
Metadata's Avatar
I see. Is there any disadvantage of cloning versus pairing a new key using HDS at the dealership?
Old Mar 11, 2017 | 09:51 PM
ezone's Avatar
For the user, no obvious disadvantage. IMO.
For the next dealer tech using the dealers HDS scanner who tries to do any repairs (immobilizer and/or PCM related) requiring programming using the existing keys (including the cloned key), it could become a little confusing. A sharp tech with working brain cells should be able to figure it out, but others may give up as soon as the process doesn't go as expected.
Old Mar 18, 2017 | 12:32 PM
Metadata's Avatar
The 8E chips arrived!
Old Mar 22, 2017 | 12:09 PM
Metadata's Avatar
Old Mar 22, 2017 | 02:38 PM
Metadata's Avatar
Just had the keys paired to the car. I now have three working keys! (I only received one key when I purchased the car last month)
Old Mar 22, 2017 | 09:35 PM
ezone's Avatar
So what process actually took place?
Were the two new keys individually registered to the car, or were the two new 8E chips cloned to match the one original key you received?
Old Mar 22, 2017 | 09:55 PM
Metadata's Avatar
I am not exactly sure what the locksmith did.
He plugged a unit into the OBDII port, put the original key in, and did some on-off sequence according to the computer plugged in, and then switched to each of the new keys until the computer told him it was done.
Maybe it was cloned?
Old Mar 22, 2017 | 10:04 PM
ezone's Avatar
Ah, I see.
You described the procedure for registering keys to the car using a scantool.
The car would probably not be needed if he were making clones of an original key transponder.
Old Mar 22, 2017 | 10:12 PM
Metadata's Avatar
Ah, I see.
Yea maybe it was actually "paired" and not "cloned".
Who knows what the disadvantages of either method is. There probably isn't enough people who have aftermarket keys who had to have something fixed at the dealership and something questionable popped up.
Only time will tell I guess, but I am happy to have at least two spare keys now!
Old Apr 20, 2018 | 10:43 AM
upallnight's Avatar
From your description of the process, the locksmith just registered the new key chip with the immobilizer computer in the car.
derykisonder
Jun 11, 2023 04:08 PM
Shingkyo
Jul 25, 2011 01:04 PM
DeathKitten
Mar 27, 2011 08:08 PM
George McQuilkin
May 1, 2010 11:39 PM
randomracer
Jun 18, 2008 12:01 AM
