Start up problem for GD1 L13A please help
Old Apr 2, 2017 | 11:45 PM
Ken Lau's Avatar
I have a 2006 GD1 L13A Jazz, have a start up problem recently. cold start no problem at all (start up less than 1 sec), when the engine cool down 30~60min, feels like don't want to start, cranking sound take 3-4 sec, but no fire, If you do it again, will start immediately. Everything is perfect and runs well, except this. Checked battery is ok, alternator working (14.3V), 8 spark plug change 6month ago, still new, 8 coil pack checked when engines one and unplug the cable one by one (may be I am wrong), but feels like all pass.....what other parts will failure in this situation.....it's really brother me, any people have this problem before ? Or idea ? Thanks heaps 🙏🏻
Old Apr 2, 2017 | 11:58 PM
dwtaylorpdx's Avatar
Fuel pump check valve is letting the fuel drain back. ?? FUel pump relay getting bad. ?
Old Apr 3, 2017 | 12:51 AM
Ken Lau's Avatar
but it's act normal when the engine is on, no hesitations and any play with rpm. Will the bad fuel valve or relay case the start up problem ??
Old Apr 3, 2017 | 01:12 AM
some cars if the pump check valve sticks open it lets the fuel siphon back in to the tank so it has to re-prime itself each time you start. Your relay may not be triggering during starting ,,, come to think of it you might load test your battery?
Alexswirsky
Apr 8, 2024 10:36 PM
Park
Dec 25, 2017 03:46 PM
mikestvn
Dec 15, 2015 01:41 PM
kupono64
Jul 1, 2009 07:53 PM
Rattus The RAT
Sep 25, 2005 09:30 PM
