Cylinder Misfire but not Coil Packs or Plugs
Old Jul 11, 2017 | 06:59 AM
doctor J's Avatar
What is the mileage on your fit? Did you do compression test?
Old Aug 10, 2017 | 05:55 AM
Robletto's Avatar
Originally Posted by frethack
Hello Everyone,
Im new, so go easy on me!
My 2007 Fit Sport is throwing codes P0300 and P0302 for random misfires and misfires in cylinder #2 (the dreaded fit curse). Ive just replaced the coil packs with Hitachis (not the best, I know) and all of the spark plugs are gapped to spec, though they are at maximum.
No matter if I switch out coil packs and spark plugs, the misfire is always in cylinder #2, so I think that those two items can be ruled out. Where should I go from here?
Im sure that there is an answer in the forum that I am just not finding...probably multiple.
have you fixed the problem yet? My Honda fit is still running with engine light on, no idea what the problem is, let us know if fixed, good luck
Old Aug 13, 2017 | 04:28 PM
dwtaylorpdx's Avatar
Discussed till the keyboards are wore out,,
Plugs - Coil Packs - Adjust valves. Every 80K (Give or take) and you wont likely have this problem.
I don't care what Honda says they are wrong.. the valves need run regularly on this engine..
JCasey
Feb 13, 2019 06:27 PM
codenamezero
Mar 2, 2014 04:00 PM
Harriswt
Mar 19, 2013 01:56 PM
Mr_Kunio
Aug 10, 2011 12:33 AM
Koi
Feb 24, 2010 01:28 AM
