Replace oil pan
Old Jul 10, 2017 | 01:04 PM
rumleyfips's Avatar
Replace oil pan
Someone repaired the oil pan with epoxy and it has started to leak. I found a used one ( manual - scarce ) to replace it.
It looks like there are 4 bolts for the air conditioning compressor . Do two of them mount on the block and 2 on the oil pan. I'm hoping I can get the oil pan off without removing the compressor entirely.
What is the best way to remove the old gunk before applying new sealer ?
Is torque important for oil pan bolts
John
Old Jul 10, 2017 | 03:07 PM
rumleyfips's Avatar
Found the torque specs; 8.7 ftlb.
John
Old Jul 10, 2017 | 04:13 PM
doctor J's Avatar
Once you remove the drive belt move compressor toward the radiator to get about 1 to 1.5 inches of clearance (the a/c compressor must be fully unbolted from the pan)
Old Jul 11, 2017 | 01:36 PM
rumleyfips's Avatar
Thanks Doctor .The new oil pan got here this morning and I see the four holes for the compressor. I still can't see the two top bolts but maybe taking the inner fender off will help.
Old Jul 15, 2017 | 06:59 AM
john380's Avatar
You also have to remove the drive shaft heat shield on the back of the engine (m/t only) dipstick tube, clutch cover inspection plate, and two large bolts (m/t or three a/t) on either side of the cover (47 lbf-ft). There is also a o-ring for the oil filter supply tube leading up to the block and a rear seal that should be replaced. I'd use a metal scrapper to carefully get the old liquid gasket off and clean all sealing surfaces with a towel wet with brake cleaner.
Old Jul 16, 2017 | 01:45 PM
rumleyfips's Avatar
Thanks John:
I have it apart now and got the parts. But...I decided to put a new belt on and when I took the old one off I didn't like the bearings in the alternator. A new one fom ebay will be here in a week or 10 days. Now I have lots of time to put the new pan on .
Old Aug 2, 2017 | 11:08 AM
rumleyfips's Avatar
Got everything together, thanks for the help.
The new serpentine belt was fine for 50km then the outer groove disappeared and the cord wound around some stuff. I don't see anything that could touch the belt. Is there anything I should check?
John
Old Aug 2, 2020 | 11:17 AM
thats_it's Avatar
Did you have any trouble screwing in the new oil filer holder (nipple/plug)? It is not going in by hand and I don't want to force it...
Spooling
Aug 12, 2024 01:13 AM
bargainguy
Jan 22, 2019 04:34 PM
SilverEX15
23
Jul 31, 2017 03:06 PM
Skwigelf
Apr 27, 2016 11:47 PM
isis07734
Dec 8, 2013 03:59 AM
