Door locks only work at certain times
Old Aug 16, 2017 | 11:13 AM
oskie's Avatar
Hello, I have a 2007 Honda Fit. I'm having some door locking issues. The driver door doesn't lock with fob but will unlock when it is locked. I can hear the motor working just fine. When i manual lock it with the power button inside it works just fine untill i do it a few times then all the doors will not lock. So i checked all fuses and relays relating to locks and didn't see anything wrong. I replaced relays 1 and 4 and the problem still there. Another issue is when car is on and locked as soon as the lights are turned on the driver door automatically unlocks. I have no idea what is wrong. I looked at youtube and a guy said the multiplex computer could go out? Any help will be greatly appreciated.
Old Aug 16, 2017 | 11:22 AM
GAFIT's Avatar
Strange symptoms! There have been recalls for the headlight switch and I believe one for water intrusion into the drivers door. Do you know if the recalls were performed?
I would bet that water has caused an electrical issue.
Old Aug 16, 2017 | 11:27 AM
oskie's Avatar
i went to honda two weeks ago for two recalls on the airbag and master switch were the only two showing up so i assume they have been done.
wutangben
Jan 19, 2020 05:18 PM
09Fitter
Jan 14, 2015 02:12 PM
skytree
Oct 4, 2014 06:50 AM
thelate1
Jan 31, 2014 04:53 PM
AES
May 28, 2005 04:41 PM
