Seat Belt icon not light up
Old Sep 2, 2017 | 07:22 AM
sav_fitatsos's Avatar
hello guys, I see that my Seat Belt icon not light up on dashboard when not use seat belt, anyone know where and what fuse I must change ?
I mean this icon on dashboard: Name:  maintSeatBelt-300x168.jpg
Honda fit 03
Old Sep 3, 2017 | 10:10 AM
Carbuff2's Avatar
Does the icon light when you first turn on the ignition? There is usually a 'bulb test' then.
The bulb could be burned out or the connections to the circuit in the buckle could be bad.
Old Sep 3, 2017 | 10:59 AM
Not its not light up... But when i tilt or shock the plastic (to insert the belt) the icon is light up, but again is stop light up..
Old Sep 3, 2017 | 11:41 AM
Carbuff2's Avatar
So the icon DOES light but not properly. Probably not a fuse.
I'd try to flush the seatbelt buckle receptacle, perhaps something spilled in it in the past. Use rubbing alcohol (isopropyl alcohol) which dries rapidly.
You might still have a bad connection in there. Can the passenger side buckle work on the driver's side?
Old Sep 3, 2017 | 01:47 PM
ezone's Avatar
Microswitch inside the buckle is sticking or bad? I see that in various cars sometimes.
If it were a broken wire I'd expect you could just move the buckle to make the light turn on and off.
Old Sep 3, 2017 | 03:43 PM
When icon is light up and put the belt inside to plastic its ok icon dissapear, but after i remove the belt or turn off car the icon not light up...
Old Sep 3, 2017 | 03:48 PM
ezone's Avatar
If you're good with wires and a voltmeter you can test it.
User1
Oct 23, 2017 09:26 PM
Soon2015FitWillBeMine
Nov 9, 2015 02:09 PM
Shockwave199
Apr 5, 2010 11:23 AM
Telix
Oct 5, 2007 02:34 PM
brdss
Jun 21, 2006 02:41 AM
