ABS seems to enable when slowing to a stop
Old Oct 11, 2017 | 02:59 PM
MyooLah's Avatar
It's common to have the last car length or two of asphalt before a stop sign/light be warped around here. When I slow to a stop on these warped areas, I'm hearing and feeling what sounds like the ABS starting to enable. Anyone have this issue? Is this a stability control thing or an ABS thing? I just want to make sure this isn't a sign of something wrong. I'm hoping to smooth the ride out with larger wheels and tires this year.
Old Oct 12, 2017 | 06:26 AM
doctor J's Avatar
From my experience, the front/rear tire thread dept difference causes ABS to activate when braking on the speed bump (not before but right on it)
Old Oct 12, 2017 | 08:02 AM
Carbuff2's Avatar
You might want to feel the centers of your wheels after a drive.
You could have a caliper binding which would make the wheels hot. Left and right of each axle should be similar temps. It's normal for the fronts to feel warmer than the rears.
Old Oct 16, 2017 | 09:22 PM
MyooLah's Avatar
Thanks, gentlemen. There's a good difference between the front and rear tread. I'll keep an eye on the wheel temps, too.
Jimmmmmy
Jan 24, 2011 12:02 PM
wskwong
Jan 1, 2011 05:15 AM
743power
16
Aug 19, 2007 07:54 PM
p1driftfiend
May 19, 2006 07:17 PM
axis.sioux@gmail.com
May 4, 2005 04:44 PM
