Steering jerking at high speeds
Old Apr 11, 2018 | 08:52 AM
Sean McKenzie-Mardelli's Avatar
2007 Honda Fit (305 000km/190 000mi)
When driving at speeds above 80km/h (50mph), the steering will intermittently experience episodes of jerking from side to side. The movements are quite noticeable WHEN they occur (feels like the wheels are suddenly disconnected from the steering system and that they are freely turning from side to side by a few degrees). The changes in direction of the vehicle can be corrected with reactive steering. Each episode lasts about 2-3 minutes and then subsides for about 5 minutes. If brakes are applied during an episode, the car will have a strong vibration.
I tried taking the car into a parking lot to reproduce the issue by “almost” doing doughnuts (slow enough so I don’t break traction) but the handling seems perfect at these speeds. However, when doing the same thing in reverse, I hear a scraping/rubbing sound with oscillatory volume.
Thoughts?
Old Apr 11, 2018 | 08:59 AM
Recent relevant repairs:
1. Left tie rod end replaced May 2017
2. Both links replaced Sept 2017
Old Apr 11, 2018 | 04:20 PM
GQ_Style's Avatar
Are you lowered? Did you get an alignment after the steering work in 2017? If you did alignment, please post up caster, camber, and toe numbers. Higher caster increases high speed stability.
Old Apr 12, 2018 | 07:50 AM
Carbuff2's Avatar
Other questions: Are your tires old (might have a shifted belt inside the tire)
Likewise, pothole damage (slight wheel bend) or if aftermarket wheels, perhaps they are not properly hub-centered.
You need to inspect the front end for play (loose bushings, ball joints, or tie rod ends). And, don't forget to inspect the driveshafts near the collars in the middle...the shafts have been known to break from exposure to salty conditions.
rifratkin
Nov 17, 2023 02:36 PM
BixLives
Dec 21, 2011 10:12 PM
luv4jdm
Feb 23, 2009 01:19 PM
owner2009fit
Sep 28, 2008 07:25 PM
bobbied
Jul 9, 2007 04:19 PM
