More HP N/A?
I have pie cutters on my car. Any idea what they weigh? I ask because I also have a set of Mini "Holies" I bought for $100, but I'm not sure if they'd be lighter. According to a forum post on a mini site, they're 12.1 lbs, and look like this, but white:
I would never think a 1.5L SOHC would make lots of power from bolt ons. I was more hoping that there was something I was missing, that "one more piece" that could get it a little more power.
M3 is nice, but if I were going European, it'd have to be British (I'd love an early 00s XKR or XK8, or a Triumph TR6, or a mad as a hatter TVR). I've kinda wanted to do a rat rod, and there are a lot of bodies available right now. One is only $100 if I can pick it up. A full 1941 Ford something with all the sheetmetal but nothing else.
Caddies make a nice sound. Northstars are pretty smooth motors, too. I like British cars because the British love cars, and they make them as things to be enjoyed. They have character and soul.
Bwahahaha thats ~$110/whp
For the amount of torque you pick up (which depends greatly on who's dyno you are using and what correction factor..) with your $200 + shipping pulley, you could just use $12 in colder spark plug and splurge an extra $2-3/tank on better fuel.
I do have I/H/E but frankly its just for noise and show lol
The best way to make a worse car better .. is to buy a better car
In almost all circumstances you can find something that is faster or goes around corners quicker for the same price as modifying an existing car to do it. That calculus tends to break down once you start talking about large turbocharger applications, I admit that, but in general it's the case - and you don't end up having to modify your car and worry about reliability. (The latter, by the way, one other excellent reason to spec better wheels or tires rather than make drivetrain changes).
So in this case, just off the very top of my head, I can think of the Ford Focus, Mazda3, Veloster if you want new. Note that I considered all these cars before buying a Fit, so you can tell what I decided, but if you simply want more power they are all faster. Lightly used? Civic Si, Acura RSX, WRX, Tiburon, Mustang .. many others. Or go find someone with a heavily modified old Civic that's now worth less than what it would be stock and negotiate hard with him :P
But really, although this is good advice, also consider that it could be an enjoyable challenge making your current car better
To the OP:
Honda did a very good job of getting the most out of the L15A7 in stock form. You can CHANGE the powerband with I/H/E but you're not really making more power, you're just moving the power from one place in the rev range to another. There really isn't any super restrictive part of the motor to be improved upon with just bolt-ons. To make MORE usable power throughout the powerband you will have to mess with the internals (compression, cam, etc.), ECU tuning, and as everyone stated, will become expensive.
Turbo or supercharger is the easiest and cheapest way without breaking the block open.
Or just daily the Fit and pick up another project to mess with, like you said earlier
[QUOTE=Wanderer.;1129553]I've been curious about this. Doing both combined allows the ECU to pull more timing i've concluded? How does it run with the different plugs on 87 if for some reason 91 was not available (or i'm too cheap/broke that day )?
Runs on 87 no prob, I have forgotten at the pump a few times Pulls much smoother above 4K through redline, but again, this is butt dyno talking The Fit ECU is just too smart for bolt on's or even a piggy back to really do any good, or so every one keeps saying. I am trying to find a solution now... but no luck yet....
Agreed, I only have circumstantial evidence based on research and personal experience right now T_T
IF I can find a tuning solution for the GD ECU I will more than happily post all of my info and dyno charts from stock pulls with bolt on's to the final results. If I only get an additional 3-5whp I am more than happy. If I wanted a faster higher HP car I would have started with one
KraftWerks: KRAFTWERKS ON SPARK PLUGS
Yes I know that is a boosted car, but at the same dyno day where the high boost kit was released they tested it on a NA car and saw a 3% gain from 99-102whp
https://www.fitfreak.net/forums/cali...27-09-a-7.html
I do my best to research things before parting with my hard earned money honest!
#33
But peak numbers get all the boys in the yard to go ohhhhh and ahhhhh or say it's not worth it. Ignorant is as ignorant does.
#34
Since I can't advance the dizzy manually I guess this is my way to do so
#35
Torque is directly related to cylinder pressure and rod/crank angle. Horsepower is derived from torque over time.
Spark timing determines where cylinder pressure builds, peaks and falls off.
Spark angle is the biggest factor in torque production, all other things held equal (Cam/Valve timing, MAP, IAT, Fuel Type, etc.)
#36
^^ I think a set of IK22's still runs around $49. Only some places carry them, I got them from a local old school speed shop, Vic Hubbard in Hayward.
15 mins to change them out with basic hand tools:
https://www.fitfreak.net/forums/fit-...l15a-vtec.html
Then premimum fuel (on average costs me an extra buck a tank) and decide for yourself.
I've had mine for 30K+ and no complaints!
Oh, and DSM you have a PM
#37
Buy them on amazon, and get the non projected tip plugs.
No way should it cost you ~$50 bucks, I think a paid $12+ shipping
I got it! Should have a chance to get you a proper response tonight.
#39
since when I/H/E don't improve power? loud is undisputed. but if you don't get power with it, then you're doing it wrong... exhaust particularly is tricky stuff... and exhaust is the one which can get you bigger power contribution compared to intake (excluding FI)
i know one GE with 162bhp max power, done as per DSM formula. High comp piston, rods, cams, pnp, piggyback, etc... daily driven with full interior..
but yes.. it is more expensive than turbo.... louder... doesn't idle smooth... but as far as reliability goes, is not much difference with a turbo'ed car... oil pressure and water temp gauges will be the difference from minor breakdown to major overhaul...
kelly
11-17-2008 08:46 PM
