would a gd3 crank pulley fit a ge8
Old Oct 10, 2013 | 01:44 PM
cyanosis's Avatar
According to the bernardi site, the part numbers are different but I can't get solid enough specs to figure out if it would still work. Personally, I think you an skip the harmonics debate as the cranks on most 4cyls are too short and the RPMs low enough for it to not be an issue.
Old Oct 10, 2013 | 05:36 PM
13fit's Avatar
NonStopTuning makes a lightweight crank pulley and their website shows years that covers both GD and GE
I would still search to confirm, or you can find Non Stop Tuning online and call them up. They are in Texas I believe
EDIT its a balance issue that causes crank pulleys to screw a motor up. No issue at all if the pulley is balanced, plus all honda motors are internally balanced anyways
Old Oct 10, 2013 | 05:48 PM
cyanosis's Avatar
I had a very negative experience with nonstoptuning's service or should I say how Mike runs his business. I don't want to drag their name through the mud again but suffice to say I won't be purchasing from them ever again.
Myxalplyx
30
Dec 27, 2022 11:15 PM
Myxalplyx
13
Jun 12, 2019 11:02 PM
mikeDF
Jun 17, 2015 09:49 PM
asik
Jan 23, 2008 09:15 PM
leonine
Apr 18, 2007 09:38 AM
