2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Alternative to painting rear diffuser?
Old Apr 20, 2010 | 02:41 PM
ivtechFit's Avatar
Where you guys get em paint beside walmart? my brother try to look for rustoleum spray paint Satin Black at walmart, but no luck and how much do they run for a can?
Old Apr 20, 2010 | 02:49 PM
score04w's Avatar
home depot, lowes, any hardware store. If you really couldnt find it at any store, im sure you could find it online. Price could be from $3-6 dollars depending on the store. Mom and Pop hardware stores are usually a little more expensive, espically for the good stuff.
Old Apr 20, 2010 | 03:12 PM
ivtechFit's Avatar
Thanks for your info, i told my older brother u gotta check other store. guess he was lazy to look around.
Old Apr 20, 2010 | 03:38 PM
score04w's Avatar
i have noticed that walmart does have a lot of spray paint there, some of its crap but somethimes they got some good stuff
Old Apr 20, 2010 | 03:48 PM
ivtechFit's Avatar
i try some of them before on my gsr, i painted my side skirt to flat black. after a few days the paint started to peel off, i was pissed shit happend
Old Apr 20, 2010 | 03:59 PM
beangrower's Avatar
Originally Posted by Choro-Q_Fit
There is another post floating around where the OP used pin strip tape to out-line the diffuser part because it bend easier around the round part and then use regular painter's masking tape to seal up the rest of the bumper area. I believe he prep the diffuser part with scotch brite before using primer and paint. My TW is also painted satin black and I have to say it looks a lot sportier, meaner and overall better.
so scotch brite is enuff to prep the surface before paint? i hear sandpaper but dont know which grit to get or start with.
Old Apr 20, 2010 | 04:30 PM
Black3sr's Avatar
I used Krylon primer and satin black. Also Scotch Brite. It is peels will redo using sandpape but I think the Brite took enuf off for the primer to grab.
Go here for pics https://www.fitfreak.net/forums/fit-...tml#post841241
Old Apr 20, 2010 | 04:42 PM
Btrthnezr3's Avatar
I used Krylon Fusion. Did not sand, just cleaned the area very well.
Old Apr 21, 2010 | 01:40 PM
beangrower's Avatar
^ i just bought that from walmart: Krylon: Products: Fusion for Plastic
it says no need to primer. did u primer urs? i might jus scotch brite the area jus in case.
Old Jan 30, 2011 | 02:59 AM
somaFIT's Avatar
i did this like a two weeks ago..used this spray paint called plastic dip
the paint sprays on an turns into thin rubber plastic..i painted once and didnt come out good so i just peeled it off like it says..crazy that you can peel the whole thing off if you dont like it..didnt mess up my original paint either Specialty Protective Coatings & Adhesives, Protective Foam Coatings, Dissipative Coatings got it at home depot
Old Jan 31, 2011 | 04:04 AM
gohdunlam's Avatar
try plasti-dip, u just cut and peel =)
Old Feb 20, 2011 | 11:29 PM
  #32
hatchpat's Avatar
https://www.fitfreak.net/forums/pict...pictureid=3309
Click on picture link for mine.
Used the black spray, no primer.
Old May 18, 2011 | 02:14 PM
  #33
ian-white's Avatar
how has it held up i was thinking of doing this
Old Sep 7, 2011 | 04:19 AM
  #34
bunz559's Avatar
i think it looks great painted. big thumbs up over stock. but there aren't any alternatives that aftermarket companies make? wow... seems to be a lack of interest in these years.
Old Sep 7, 2011 | 06:50 AM
  #35
Black3sr's Avatar
An after market item is not required. Just jack it up and spray it. Mine is still fine and has been through a winter.
Old Sep 7, 2011 | 10:35 AM
  #36
Btrthnezr3's Avatar
Mine has been painted since I think March of 2010...still looks great!
Nomar
Aug 16, 2014 09:53 AM
fitevo
Oct 19, 2010 04:47 AM
Vash
Aug 31, 2010 01:06 AM
JazzTune
Jun 17, 2009 02:14 PM
Young Roids
Aug 2, 2008 09:41 PM
