Air bag seat bypass???
Old Jan 23, 2013 | 06:25 PM
Wafulz's Avatar
hi there gunnna be getting some seats soon and wanted to know how do i by pass for passenger and driver seats with out Xmas lights being on ?? any help greatly appreciate it
Old Jan 23, 2013 | 07:21 PM
Wanderer.'s Avatar
Here:
Originally Posted by Chad T
Get the brackets from Wedge Engineering. Driver's side 2148T Pass side 2149T. On the sliders there are only a couple different types from Recaro. Make sure you get the ones that say "with tabs".
You can see bracket and sliders here. I actually cut the tabs shorter on the front of the sliders so I could use the bottom mounting holes.
The tabs on the sliders bolt to the ends of the tubes on the top of the bracket.
As far as the airbag light goes..On the driver's side all you have to do is remove the seat posistion sensor from the stock seat and leave it plugged in. Just make sure it won't contact any metal.
Then just jump the airbag connector with a 2 ohm resistor. No airbag light for me and I've had my recaro in for about 3 months now. You can read more about my install here.
https://www.fitfreak.net/forums/2nd-...ll-begins.html
The passenger seat is much more complicated as far as airbag sensors. I didn't put a seat on the pass side.
DO whatever you need to do to get Recaros in your Fit!!! Makes a huge difference.
Couldn't find a thing about the passenger seat, I would assume that the airbag would be the same as the driver's seat, but there are two other sensors in the passenger seat you would have to find solutions for.
Jul 17, 2017 09:46 AM
AshleyyOnPoint
Apr 14, 2014 09:45 PM
Elephantman
May 25, 2011 12:15 PM
davela72
Sep 24, 2010 06:20 PM
fitster
Jan 30, 2009 03:08 AM
