Rear Defroster
Old Feb 23, 2019 | 08:07 PM
IfChris_ThenFit's Avatar
Rear Defroster
Hey guys,
I have noticed a few times that the bottom third of my rear window doesn't actually defrost. It doesn't REALLY affect me because I can still see fine and its safe etc. But I am emotionally irritated by it. Is this by design? If not how hard would it likely be to get fixed, I am pretty good with electronics so I cant imagine itd be too hard unless its something in the glass.
Old Feb 24, 2019 | 01:45 AM
56chevydan's Avatar
The reason a portion of the defroster grid in your rear window isn't working, is you have a scratch or break in the grid. The current that is applied to the rear window grid when you turn on that defroster, needs an unbroken path through that grid to work. When that path is broken, the portion after the break in the grid stops heating/working.
If you do a search on the internet there are repair kits out there to repair the break in the grid by brushing a metallic-like paint substance on the break that conducts electricity and bridges the break in the grid. The only other way I know of to repair it, would be to replace that rear glass/defogger grid assembly with a new one.
Old Feb 25, 2019 | 08:59 AM
fit09's Avatar
+1 on this advice. If you go to YouTube there are several videos about testing the defrost grid with a test light to locate the broken grid. After that try one of the repair kits. Otherwise you will need to replace the rear glass.
Old Feb 25, 2019 | 09:28 AM
Thanks guys, this is surprisingly easier than expected!
honda_fit_2009
Jan 4, 2019 05:01 PM
fujisawa
Aug 14, 2018 09:01 AM
ian05s2k
Jan 26, 2014 07:48 AM
littleblackcar
Oct 29, 2011 07:36 PM
wwetmor
Apr 6, 2007 03:02 PM
