AC component oils amounts
Old May 6, 2019 | 04:39 AM
Temmett's Avatar
Does anyone know where I can find out how much Ac oil I should add to my new condenser? I have an 09 fit. The compressor went bad so I am replacing the condenser w/ drier as well. The compressor comes pre oiled already.
Old May 6, 2019 | 10:24 AM
fit09's Avatar
According to my Service manual for 2009-2010 Fit the condenser oil capacity is 5/6 FL-oz or 25 ml including dryer. Hope this helps.
Old May 6, 2019 | 12:46 PM
JohnpaulX's Avatar
What compressor are you replacing it with? OEM? I'm in need of a new compressor and trying to find suggestions.
Old May 7, 2019 | 03:03 PM
Temmett's Avatar
Go to rock auto. I got a compressor, condenser, o-ring kits and expansion value for $310. I am putting it in today
Old May 7, 2019 | 03:26 PM
JohnpaulX's Avatar
That ismy plan, I just wanted to make sure it was a good compressor. Let me know how yours works.
Old May 7, 2019 | 05:05 PM
Temmett's Avatar
I got the UAC brand
Old May 8, 2019 | 12:25 PM
Temmett's Avatar
Completed the job and everything works great! Ice cold. I would recommend that you pick up new bolts for the condenser hose connections. They don’t supply any. Also the new condenser didn’t use the threaded stud and nut the old one used for the high pressure hose connection. So you will need a bolt for that anyway. Every thing was as expected.
Old May 8, 2019 | 04:09 PM
fit09's Avatar
Did you have to flush the lines or just vacuum & recharge ? Very difficult to access the expansion valve for replacement?
Old May 8, 2019 | 04:28 PM
Temmett's Avatar
Honestly I didn’t replace the expansion valve because I know my clutch failed in the compressor. When I took the compressor out I emptied the oil and inspected for contamination (metal flakes). I felt it wasn’t needed. But no flush just pulled a vacuum for 3 hr. Then recharged.
In all the years I have had a Honda I probably replaced the compressor and condenser in cars and luckily never ran into problems. If I would have found metal in the oil I would have done everything. Bottom line is it’s $20 to recharge again if I need to. I will take the chance
Old May 8, 2019 | 04:33 PM
fit09's Avatar
Thanks for the follow up. Lucky it was just a clutch failure and no metal flakes in your system. Glad things went well with your repairs.
redludesh
Jul 22, 2018 02:20 PM
laszlosujj
Jun 7, 2017 08:30 AM
sschoe2@gmail.com
Jul 27, 2016 08:40 AM
Suetjesz
Oct 1, 2015 05:26 PM
FELIXY69
Jun 9, 2010 03:49 PM
