adding USB to 2009 base
Old Jun 1, 2019 | 11:43 PM
tyler968's Avatar
Hey just curious, I wanted to know how to add USB. I’ve got the cable/cord, do I need anything else, or can I plug in to back of OEM base radio and wire through to cubby?
Old Jun 2, 2019 | 04:58 PM
Pyts's Avatar
Thats how mine's hooked up and I can verify beyond the shadow of doubt. That it sucks. If i run maps and pandora it *maintains* charge on the phone. Thats the stock setup though.
Old Jun 2, 2019 | 11:00 PM
GolNat's Avatar
The radio output would work but like Pyts said won’t supply much current (probably .5A). If you want an integrated system I would get a buck converter so that you could step the current up to 2 amps (high speed charger output). Mount the board in a project box and run a switched 12v source to the board. Output to your USB mounted where you want.
https://www.amazon.com/Ultra-small-adjustable-Compatible-Atomic-Market/dp/B00TMFKJ9Q/ref=asc_df_B00TMFKJ9Q/?tag=hyprod-20&linkCode=df0&hvadid=198062682203&hvpos=1o2&hvnetw=g&hvrand=2985829225300634013&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9007488&hvtargid=pla-319814629648&psc=1 https://www.amazon.com/Ultra-small-adjustable-Compatible-Atomic-Market/dp/B00TMFKJ9Q/ref=asc_df_B00TMFKJ9Q/?tag=hyprod-20&linkCode=df0&hvadid=198062682203&hvpos=1o2&hvnetw=g&hvrand=2985829225300634013&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9007488&hvtargid=pla-319814629648&psc=1
Easiest solution would be to just get a 12v cigarette lighter adapter.
Old Jun 6, 2019 | 06:52 PM
Steve244's Avatar
What do you mean you have the cable/cord? The stock base radio doesn't have a USB connection on it; you have to add a module that plugs into the radio. This has a custom USB factory cable (like on the Sport) that normally mounts to the inside of the glovebox.
I did this years ago, but the college hills honda link and my pictures no longer work. Here's a new link to pictures.
Consider this: HondaPartsNow. The instructions are pretty good.
Old Jun 7, 2019 | 01:33 PM
tyler968's Avatar
So the USB control module is required? I have the cord, just not the module box. I don’t care about music, just charging.
Old Jun 10, 2019 | 08:08 PM
Steve244's Avatar
If it's just charging you want, get a good USB charger to plug in to the aux power outlet below the HVAC controls.
tyler968
Jul 12, 2019 02:04 PM
Joshua S Gabrielson
Apr 11, 2014 09:33 PM
Jon H
Mar 29, 2014 10:29 PM
awill14
Mar 28, 2014 08:29 AM
thewwkayaker
Oct 31, 2011 12:35 PM
