Back up camera installation
Old Jul 22, 2019 | 04:38 PM
Nikademo's Avatar
I found a pretty neat backup camera that installs in the reverse light. It's is pretty much plug and play. Only problem is, how do I run the wires from the hatch to my dash? Seems like a pain. Anyone install one of these? I like to keep everything as clean and stock looking as possible. Thank you!
Old Jul 25, 2019 | 09:19 AM
beardedGTI's Avatar
  • Across the hatch under the window along with the other strand of cables
  • Snake through the channel on the side of the window towards the rubber grommet
  • through the grommet to hatch roof area
  • across the roof to the passenger side
  • you can now either
  1. Keep going along the roof line all the way to the front. Just peel the weather stripping back when you get to the doors, tuck into the headliner, immediately put weather strip back. This way is easier, but need to be careful about it not obstructing the airbag in the passenger b pillar.
  2. Or snake it down to the floor of the rear hatch running it to the front. You’ll need to carefully pry up the the trim pieces on the edge of the floor to do so.
  • Run across the bottom of the glove compartment and up into the radio area.
Tips:
  • Test camera before routing the cable
  • Test the mounting location especially in the dark to ensure you are happy with it. On my wife’s car the reverse light creates just enough of a halo in the corner while in the dark that it’s distracting.
  • don’t tie anything down till you finish routing and test it again
  • running rca end through the flexible grommet is a pain but can be done. A few small drops of “personnel lubricant” into the high side then massaged into the center will help.
  • Have patience and set aside several hours to do this
Old Jul 25, 2019 | 04:09 PM
Nikademo's Avatar
Tips:
Appreciate the great response! Thank you 😊
SilverEX15
Dec 16, 2017 05:46 PM
Press Fit
Sep 17, 2016 07:26 PM
goConcrcete
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 12, 2014 04:02 PM
vbearvbear
Jun 2, 2009 10:02 PM
BrianT
May 27, 2008 11:58 AM
