Towing Honda Fit
Old Sep 4, 2019 | 10:11 AM
Bigmo's Avatar
Towing Honda Fit
Can a 2013 Fit with auto transmission be safely pulled behind a RV with the front wheels on a dolly?
Old Sep 4, 2019 | 10:18 AM
Pyts's Avatar
Being front wheel drive, it certainly can. I would however recommend putting on a bumper cover and such for the front end, even if you make it yourself. Now lets hear from the experienced folks
Old Sep 4, 2019 | 11:46 AM
Bigmo's Avatar
I thought so. The question is about the steering wheel. I read somewhere that it must be unlocked, some even said to disconnect the battery ground. How valid is all that?
Old Sep 4, 2019 | 04:43 PM
Pyts's Avatar
I cant speak in regards to those specifics from experience. The battery ground thing I would think to be only an act of caution. In regards to leaving the steering unlocked, maybe the battery ties in here, to prevent the wheel from locking. I know this car has electronic power steering but never had to look into such a thing as the steering wheel lock.
I would say its fine either way provided the vehicle is properly chained.
Leaving unlocked would to me communicate a desire to avoid putting strain on the electronic power steering rack. If properly bound, this should never be an issue anyways..
Oh, I just found this!
Old Sep 4, 2019 | 07:19 PM
ANGST's Avatar
(just about) All steering wheels lock , when you turn off your car the steering wheel doesn't move . To unlock the steering wheel you need to put the key in and turn it to ACC , you disconnect the battery so it won't go dead when you do that .
Old Sep 4, 2019 | 08:05 PM
Bigmo's Avatar
Yes.it does make sense. I knew I'll get good help and info out of this forum. Thank you.
TommyMadison
Jul 29, 2018 07:05 PM
Shaun Yi Cheng
Jun 21, 2018 01:36 PM
cgwaters
Apr 20, 2016 10:48 AM
rooibos1986
Jan 20, 2014 12:30 AM
Kooper
Nov 4, 2013 04:53 AM
