Starter help
Old Oct 14, 2019 | 10:21 AM
JM80Fit's Avatar
Starter help
Hi,
I have a 2009 Honda Fit Sport automatic(112,000 miles), from the Suzuka plant, and I believe the starter has just died. It seems like it is turning the engine, but fails. I just recently replaced the alternator with a new OEM part.
Are there any troubleshooting tips?
Looking for suggestions on replacements on the starter?
Old Oct 14, 2019 | 12:15 PM
Goobers's Avatar
Are you sure its actually turning the engine? I mean, wouldn't a dead starter fail to turn an engine? IF it sounds like its cranking (normally?), then its likely something else.
I would check spark plugs and coils, especially if they're still factory parts.
If you're gonna look for parts on the cheap... you could try sourcing from a local junkyard in hopes of finding the part you need intact. I would suggest against this for maintenance items like spark plugs/coils though.
I would usually go to something like Bernardi parts online to look up the part number, then google the part number and see who online sells it for a decent price without looking too sketchy.
Old Oct 14, 2019 | 12:43 PM
JM80Fit's Avatar
The engine feels like it’s semi turning and then fails, starter sounds off too. Last week every cold morning the starter would have a loud grinding noise and then would start.
goblazers
Jan 6, 2021 08:20 PM
Sebas Td
Mar 2, 2019 11:53 AM
the_had_matter
May 21, 2016 01:05 PM
SevereService
Jun 25, 2014 08:02 PM
DCTepper
Nov 22, 2013 07:41 AM
