Dash lights not turning off when key is out.
Old Oct 22, 2019 | 10:39 PM
vishalchat's Avatar
Even when the key is taken out of ignition- these lights are on. After the car is started then it starts up; radio and all lights work except the speedometer. It remains as is with couple of more light turn on in the dash such as ABS, brakes and steering light. What could be the cause? Please help. It is 2009 Honda Fit vase model and my son is driving this car to school
Old Oct 23, 2019 | 07:05 PM
JRHPNG's Avatar
Has any electrical work been carried out recently? Sounds like you literally have some wires crossed, possibly a fried relay?
Old Oct 23, 2019 | 08:43 PM
vishalchat's Avatar
Thanks. No changes done recently. Battery was replaced last year. My son used auxiliary to connect the iPhone. I worry about that wire could have caused a surge but those are so low amperage- not sure if that can cause such a damage.
I took out the fuse # 1, 14 but nothing worked so far. What is the fuse for radio - could that be issue?
Old Oct 26, 2019 | 02:14 PM
vishalchat's Avatar
UPDATE: this worked!!
I removed battery terminals for 35 minutes and put it back after Fiting suggested it. Started the car and it’s back to life. Had to put a code for radio to start the radio. Drove around and it all good now. My son will thank you as well.
Old Oct 27, 2019 | 03:54 AM
Black3sr's Avatar
Try a reboot. Disconnect the battery for half hour. Someone else has some weird similar problem and that worked.
kybrdmn
Mar 24, 2018 08:36 PM
honda_fit_2009
Mar 6, 2018 07:51 AM
EdNull
Jan 13, 2017 09:50 AM
SoCalMike
Aug 5, 2005 02:34 PM
garcia
May 4, 2005 11:16 AM
