Code P0171 after servicing..
Old Feb 20, 2020 | 09:56 AM
testes's Avatar
Just 2 days ago, I brought my Honda Fit GE6 for it's regular 10,000km servicing. Today, the check engine light came on and showed code P0171 System Too Lean (Bank 1). Before the check engine light came, fuel consumption was at 14km/litre and dropped to 12km/litre after the light came on. Below is a list of maintenance work done.
1) Engine Oil
2) Oil filter
3) CVT Transmission fluid
4) Spark plugs
Did my mechanic screw up somewhere during the maintenance? Or is it a coincidence that my O2 sensor failed? Total mileage is at 147K.
Please tell me it's something I may be able to figure out and fix myself. Any advise is appreciated.
Old Feb 20, 2020 | 07:46 PM
punx45's Avatar
Since you have to disassemble the entire intake system down to the runners to service the plugs, odds are there’s a vacuum leak somewhere. Check for loose or disconnected hoses. Make sure all the connections from the air box to the manifold are tight. If you have an obd scanner you can get real-time airflow and manifold pressure readings too.
Rob22315
Aug 30, 2015 08:29 PM
The Barroom Hero
Mar 13, 2014 07:23 PM
bjvalencia
Oct 11, 2011 03:16 AM
hazzard
Nov 14, 2008 02:55 AM
Andrew
Jul 10, 2005 03:50 AM
