Disable rear cargo tailgate light?
Old May 14, 2020 | 10:31 PM
usert_l's Avatar
Is there an easy way to disable the rear cargo light so it doesn't turn on when rear tailgate is open? I don't want to drain the battery on occasions like camping, etc ... when I want to leave the tailgate open for my convenience. I don't think there is a control switch for it like there is one for the ceiling light.
Old May 14, 2020 | 11:31 PM
marmaladedad's Avatar
The simplest method is to remove the bulb. Otherwise, IIRC there is a rear cargo light assembly from another Honda that some Fit-owners here have swapped in that has a toggle switch to shut off the light.
TnTkr's Avatar
An easy and smart way to do this is to replace the original light with the one that has a switch. Honda part 34265-SFE-003 has been mentioned by many people in this forum and it does not require any modifications.
Old May 15, 2020 | 08:16 AM
2Rismo2's Avatar
As well as replacing the the unit that has a switch, look into LED in case you inadvertently leave it on. I changed all the interior bulbs to LED and accidentally left the door ajar in the garage. Car still started in the morning. I don't think I would have been able to with conventional bulbs
Old May 15, 2020 | 12:30 PM
usert_l's Avatar
Thanks for all your answers guys. I went ahead and just took the bulb out. Very easy to do all needed was a flat head screw driver to pop the light assembly loose.
Old Jun 14, 2020 | 12:32 AM
tpet's Avatar
Swapping for the light with the switch is as easy as this, I just did it on mine so now if I need to leave it open for a while I can just hit the switch. It’s a cheap part and pops right in.
Old Jun 14, 2020 | 10:02 PM
Hootie's Avatar
... Or just get a cargo light from any Honda with the selectable on/off switch.
Part number is 34265-SFE-003.
Source vehicles are HR-Vs, Accord Crosstours, and 5th/current gen CR-Vs.
View this post on Instagram
littleblackcar
Jun 8, 2018 10:38 AM
kellyjoy
Apr 22, 2015 11:09 PM
TheRealBenzo
Sep 22, 2012 03:35 AM
motorman
Aug 13, 2010 07:50 PM
MikeFL
May 5, 2008 03:50 PM
