2012 intake problem…. Help please
Old Dec 29, 2021 | 10:22 PM
WaRdO83's Avatar
What’s going on guys…. So my delema is I bought everything to make a short air intake and once I removed the stock air box and installed the dam intake the car ran like shit… it was sputtering and had no throttle response. So I gave up and reinstalled the air box and put a k&n filter in there.
I guess the question I have is what did you guys do if building your own intake and please help me out. I know I ain’t going to make major gains, but would be nice to hear her growl a little more.
Old Jan 4, 2022 | 09:35 PM
2ndGen's Avatar
From what I've read you need to make sure the diameter where the MAF is doesn't exceed 2.5" otherwise you'll get bogging problems, lots of people end up cutting the MAF section out of the stock airbox & using that with the other piping to keep the diameter @ 2.5"
Old Jan 4, 2022 | 10:40 PM
WaRdO83's Avatar
I guess the one I bought is 2.95 inches… I figured it would work since if fit the factory sensor…
Old Jan 5, 2022 | 01:15 PM
steve37's Avatar
HPS intake from Amazon on my 2010. Have had it on for three years now with no problems at all..
Old Jan 5, 2022 | 06:08 PM
eulogy's Avatar
as 2ndgen stated, the diameter around the maf needs to be precise. yours is too large, which directly relates to the bogging. crazy how intelligent our silly little cars are.
Old Jan 5, 2022 | 06:41 PM
Pyts's Avatar
HPS is a legit company. After reading the above I did look up how MAF sensors work. It's dual temperature sensors where one is heated and one isn't, and it measures the difference between 'em. The actual figuring is handled by the ECU. Based on what I could find, the computer gets the info from the MAF sensor, along with others, and calculates the flow rate with some fancy equation.
With some googlery I found this: "To calculate Air Flow in Cubic Feet per Minute (CFM), determine the Flow Velocity in feet per minute, then multiply this figure by the Duct Cross Sectional Area."
So I think the equation requires a set diameter, at least (based on my findings) two inches to either side of the sensor.
​​​​​​​The HPS intake has a diameter of 2.5". I think the consensus is that the part you got would require reprogramming of your car's ecu to work.
Old Apr 23, 2024 | 02:16 PM
2010fitnoob's Avatar
were you able to figure this out? I'm having the same issue now and im guess my solution will be the same as yours if you found one
Myxalplyx
Jul 15, 2019 03:26 PM
Myxalplyx
Apr 11, 2015 09:56 PM
Cordizzle4life
Jan 5, 2012 11:50 AM
Rod2Rice
Jul 24, 2008 11:06 AM
